marino1310
- Aug 16, 2017
Hi, im new here and not sure if this is the best place to ask, but I have a smithy 1220 ltd 3 in one lathe mill. I wanted to add a variable speed powerfeed to it for awhile and was wondering if you guys have any advise on it?
As it sits, the smithy has a 2 in one leadscrew that can engage with the half nut for threading or the worm gear can engage with the keyway notched in the leadscrew for powerfeed. My only issue is that powerfeed requires you to mess with the change gears for speed adjustment, which takes forever on this lathe. So I was wondering if there is any kind of "universal motor" that I can buy relatively cheap and attach it to the lathe for a variable speed drive. I plan on attaching it to the end of the lathe by cutting a keyway into the end of the leadscrew and putting the motor between the screw and the handwheel.
