plastikosmd
Hot Rolled
- Sep 6, 2003
- New England
Non operational saw with an issue with varidrive. When I got the saw, the belts were hanging loosely and the Drive was locked up. I have searched prior rebuild threads and on the Internet, looking for parts diagram or breakdown on how shaft that supports the sheaves operates. I have not found much. The rear pulley sheave was free spinning and had sheared the two smaller Allen screws that kept it keyed to the shaft.I am also assuming that the larger portion of the shaft (that the sheaves are keyed to) should be free spinning on the smaller shaft. Right now, they are fused solid together.
My question is: am I correct in assuming that the larger part of the shaft should spin on the smaller shaft supporting it?
The shaft, acting like one solid unit(spun bearings/seized??)I did not want to start pressing these two things apart without knowing how they're supposed to function. If they are to spin, how are they secured together, is there snap ring that I am missing?
