spock
Stainless
- Dec 29, 2006
- Central Ky
Simple shaped parts, 7" dia. cylinder with 3.5 thru hole, 3.75 long. Wrapped and heat treated, 1200 for ten minutes, then 1850 soak for 3.5 hours. Allowed to cool down to handling temp, I checked the hardness after air cooling, 59 HRC average, right on what I was shooting for. Then tempered at 960 for 4 hours, with the plan of completely cooling down, then second temper at 900. I did a hardness check and now I am getting about 40 HRC, which will not do at all.
I have been religiously following the instructions in William Bryson's book, "Heat treatment, selection, and application of tool steels" for a couple years now and have had pretty good success, but am now at a loss.
Is it possible that I have a softened layer at the surface? I can set these parts up in the lathe and turn a bit off, as they do have stock on them. I just dont want to cut too much, just in case I have to send these out to be "fixed" and heat treated again. Any ideas on what is going on? I'm all ears.
