Does anyone know where to purchase Tungsten Carbide Stock from???
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Jul 2007
    New York
    76
    Default Does anyone know where to purchase Tungsten Carbide Stock from???
    I'm looking to get a round stock/piece rougly about 1/2" in Diameter. Does anyone know who sell this type of material and stock??? Thanks
    Apr 2008
    Troy, NY
    495
    76
    McMaster carries it in a variety of diameters, shapes, and lengths.
    Any cutting tool supply should have it.
    Henry Wettersten
    May 2002
    South Central PA
    12,667
    1661
    2824
    This is a good place to get Carbide - http://www.carbideprocessors.com/materials.htm
    Jul 2004
    Houston, TX USA
    27,452
    Another vote for Tom Walz's place. The best.
    John Oder
    Oct 2006
    williamsburg va
    7,886
    839
    1713
    The machinery salesmen at MSC can put you in contact with a carbide manufacturer who can custom make carbide to your needs.
    May 2006
    Tacoma, WA
    1,270
    426
    282
    Thank you, Gentlemen.
    Yes, we can help with round rod and are happy to do so.
    Tom
    Jul 2007
    southern california
    221
    If it is a short piece you might consider an solid carbide end mill. ebay, or on here?
    re
    Jul 2007
    New York
    76
    I'm trying to make a 6 slotted external spline out of the 1/2" OD Tungsten Carbide. I have an attachment of what the spline looks like (ignore the outer circle in the picture and treat the inner part as if it's the cross section of the external spline). The OD of the spline is 1/2" and the ID of the .480., and the slot are .0889 wide. I trying to figure out how to cut the 6 slots into the Tungsten Carbide. Does anyone have any suggestions???
    Aug 2007
    Bakersfield, CA
    757
    74
    I'm thinking sinker EDM? Although I'm not sure how deep they can go before chip flushing becomes an issue. What would the length of the part be?
    Jan 2007
    Flushing/Flint, Michigan
    6,328
    259
    5148
    Part in indexing head.
    Slot with grinding wheel just like you would put flutes in a reamer.
    Slots are only .010 deep? Whats the min. allowed radius in the corners?
    Are you sure you want to make this from carbide?
    If it has to take any kind of beating (forward/reversing under load) you'll want a die grade (coarse grain, lots of cobalt).
    Bob
  11. #11
    Jul 2007
    New York
    76
    about 9" in length. You couldn't use an end mill to cut the slot???
  12. #12
    Jan 2007
    6,328
    259
    5148
    Quote Originally Posted by brianklein View Post
    Nope, you can't mill carbide. (except in the "green" state before it's been sintered and it can't be shipped to you in the green state or it will fall apart)
    Do the splines have to run full length?
    Bob
  13. #13
    Sep 2006
    SE PA, Philly
    5,142
    935
    1627
    Tungsten carbide is among the hardest materials known.
    Cutting carbide with a tool steel endmill would be like cutting a kitchen knife with butter. Cutting carbide with carbide, like cutting a stick of butter with another stick of butter. Will destroy both your workpiece and the carbide end mill.
    As a previous poster asked, why is carbide your material of choice? It is more brittle than other materials.
    If this is to transmit power, why are you using cutting tool material?
    Jim
  14. #14
    Jul 2007
    New York
    76
    I though that Tungsten Carbide was very strong (provided that it has a lot of Cobalt). Plus i am using this spline for a task that will require it to be extremely tough.
  15. #15
    Jul 2007
    New York
    76
    Bob
    yes they do.
  16. #16
    Aug 2005
    Tacoma Washington
    1,338
    84
    124
    According to my limited understanding, Tungston Carbide is a very hard metal, but can also be brittle. I would think that you would be better off using a different kind of steel, one that can take the sudden loads that might be incured in power transmition without shattering.
  17. #17
    Aug 2007
    Bakersfield, CA
    757
    74
    Sorry for my earlier post, missed the part about ignoring the outer circle in the drawing. Duh.
    There are tougher grades of carbide formulated for impact resistance; I haven't gotten around to it yet, but at work sometime next week I'll be sourcing some carbide stock to make replacement peens for an orbital riveter. I'll let you know what I find.
  18. #18
    Jan 2007
    6,328
    259
    5148
    Carbide is very hard but not exactly tough.
    Clamp a piece of 1/2 rod in a vise and hit it sideways with a hammer and it will break.
    Carbide is a powered metal with a structure much like concrete.
    A column can take a huge load in compression but you can break it in half with a sledge hammer.
    Toughness is increased by using large grains and lots of cobalt. These are C-12 through C-14 grades. Generally known as impact grades.
    We use these for things like facedrivers, punches or hammers for recycling plants. Again these are compression applications.
    Maybe think about something like a piece of O-1 drill rod and have it heat treated after machining.
    Your part could certainly be ground with diamond wheels but I think you are looking at the wrong material for your shaft.
    Bob
  19. #19
    Jul 2007
    New York
    76
    Bob
    What is O-1 drill rod???
  20. #20
    Jul 2006
    Webster, MN
    687
    9
    O-1 is Oil hardening drill rod tool steel. I would recommend a piece of 4140. That's the stuff the make axles out of. Very hard, very tough.
