viper
Titanium
- May 18, 2007
- nowhereville
I am fighting a starting problem with a GM 6.5 TD truck. Been fighting it almost since owned. Bats sit at 12.6V with no load and pull down to 10V during starting which is a 400A load. It has dual 600cca bats in which one is new and the other is, well, not. I can test each bat for current, etc but everything I am getting from OEMs is the bats are just fine.
They say 400A on a bat system of 1200cca dropping to 10V is fine. IMO, that is a problem. Further more, the best I can tell, I have a 4ga copper cable from main bat to starter. That cable is seeing .9V drop. The HUGE cable coupling the batts is .25V drop.
So, if my bats are pulling down to 10V and I have .9Vdrop on cable, my starter is seeing near 9V. The truck turns over slow and as any diesel wrench knows, diesels gotta spin to get going. I am not sure that is all my problem but probably some of it...
Any experiences? Anyone willing to go unplug their injection pump and crank for 5sec and see what you get for Vdrop? Current? I am about to push this truck off a cliff....
