rdhem2
- Oct 11, 2012
- Yakima, Eastern Washington, USA
Here Is the challenge. A Gent brought me a set of rotors from a dragster he is reconditioning. Rotors look all but new. Problem is the machine sat so long that the brake pads have left rust marks and pits on the rotor and he wants a skim cut taken on both sides.
He took them to a couple brake shops, even Les Schwaub's, and they would not touch them. Seems they have a weird five hole hub pattern and no one has the set up to turn them.
My experience is they want to chatter and squeal like the dickens when turning. Not inducive to an acceptable finish. Replacement is spendy as it is an obsolete pattern and the manufacturer wants $347.00 each to reproduce them. Duable but not desireable.
I can turn them if I make a proper jig. I could grind them with a tool post grinder. I could grind them by turning on the Cincinatti #2 tool grinder. I could flat grind them on a surface grinder. Anyway I do it will require aa jig of some sort.
What is your vote for machine and procedure?
