Connor_U.
- Feb 21, 2016
- Wisconsin, USA
Greetings!
I have been given the task of searching for methods of detecting broken tooling for our CNC Drilling machine.
Our drill machine is a CNC operated gang-drilling machine use to drill holes into paper rolls. This machine utilizes 180 drill heads driven in tandem by a spine shaft. We are looking for a good way to help us sense when drills have broken during a drilling cycle.
The main challenges we have are as follows:
1.) With up to 180 drills that could possibly be in use at a given time, a laser sensor on each drill head would likely prove to be too cost-prohibitive and cumbersome to integrate to the machine. It may also be difficult to use such technology during use with our coolant system, or when we are making heavy chips.
2.) Ideally, we want to be able to detect broken tools before, during or after a drill cycle is complete. If a drill breaks and sticks in the metal shell of a roll during entry, the broken end remaining in the collet may continue to feed into the roll, and can cause significant damage to the roll cover. We are typically drilling into a pre-existing hole, and when a bit breaks, but does not stick in the hole, we want to be able to detect the broken tool in the collet after it retracts, and before it goes to the next cycle.
3.) The cutting forces generated by this machine are created by dozens of tools cutting at the same time, so overload sensing would be very difficult to detect for a single broken bit. Our most commonly used drills are fairly small (.125"-.176"), and do not generate spikes in cutting forces when they break.
My questions:
1.) Are there any options out there that could visually sense that many tools at one time, and perhaps be integrated into our control to stop the machine if/when it detects a break?
2.) Are there any options that use audio frequency detection? When bits break outside the shell, they make a pretty distinct noise which we feel could potentially be used as a source of detection.
I have attached a few images of the machine to show the setup of the drills. Any advice is greatly appreciated!
Thanks!
Connor
My questions:
Thanks!
Connor
