Hello all,
I hope this is the right area for a noob post like this but here goes..
I have a HQ400/3b lathe/mill and the spindle has a flush mount setup for mounting chucks.
This has a 72mm step/register which the chuck locates, and three bolt holes to pull the chuck snug. The bolt holes are 84mm PCD.
I bought a four Jaw chuck which has the same register (72mm) and the same PCD (84mm) but has four bolt holes instead of three.
The question I have is:
A, do I drill and tap two new holes in the chuck (can use one of the existing holes this way)
Or
B, drill two new holes in the spindle face (again utilising one of the existing holes)
Or
C, make a backplate which permanently mounts to the four Jaw chuck?
If anyone could offer some advise that would be great cheers
Or
Or
