MetalWorkingFAQ.NET
- Jun 20, 2006
- USA
Hi everyone-
We have been having serious problems drilling both 3/16" and 1/4" holes in 304 stainless using the following: HSS, HSS TiN, Cobalt, Cobalt TiN, Cobalt TiCN, Cobalt TiALN drill bits in both sizes at a depth of 1" (effectively 5.3X and 4X) with speed/feed of 1018RPM/3IPM for the 3/16" for example. We're flood cooling and using a VMC to do this. Bits burn up, die, work-harden the hole and we're SOL. Using the CNC, we used a peck drill of .1875 and it worked fine for a test piece and then in the actual customer piece, the first holed failed.
Doing this manually yields better results. In fact, manually, using the 1/4" cobalt bit with 118degree point works the best. The chips need to be cleared after every plunge from the flutes and the hole and bit need to be generously re-lubed, but it's yielded the best results (i.e. holes can be drilled at least...) so far. I
Two questions:
1. Using CNC, what would you all recommend?
2. With the tip of one of the 3/16" bits in a hole that didn't make it, how can we extract it? It needs to be a through hole. EDM?
Thanks!
Two questions:
Thanks!
