Drilling small holes in 304 stainless steel
Results 1 to 8 of 8
    May 2007
    Wixom MI
    29
    Post
    Ok, I need some input on this. I need to add 4 holes 1/16" diameter in 304 Stainless Steel. I will be drilling about 1/2" deep and breaking out into a radius. Anyone have any ideas?
    Feb 2006
    Indiana
    242
    Post
    Start on the flat side. Spot drill. Use sharp drill. Use cutting fluid. Not a big deal otherwise.
    Randy
    Jun 2007
    Perth,Western Australia
    53
    Post
    Using white vinegar on stainless, especially 316 makes drilling a cinch. I don't know why or even who told me but I have used vinegar and it really does work well.
    Jim
    Jul 2007
    ontario
    145
    Post
    peck drill and make sure you clear the chips try an acid brush in one hand and the handle in the other maybe a little dish of cutting fluid to dip and apply coolant.
    Feb 2007
    Birmingham, AL
    190
    Post
    drilled about 40 316 and 40 304 bolts the other day, with 1/8" bits.
    had to resharpen the bit every 12-15 holes. all we had was sulfur oil, so it was used.
    no biggie, just paying attention to the bit and keeping it sharp worked well.
    1/16" bit would mean I'd go find some bacon grease or something heavy and fatty.
    i'm prolly wrong again with what to use , but my bible is at work...
    Jun 2007
    Warwick, RI
    184
    8
    24
    Post
    There's nothing too special about 304. I machine 316L all day. Not much different. I usually drill 60 sfm. On a 1/16 drill, I'd probably peck drill it with a .0005" to .0007" feed. We've had every coolant under the sun where I work. Currently using a Castrol vegetable oil based coolant.
    Jun 2007
    New Zealand
    2,661
    28
    Post
    Don't ever let the drill dwell or rub (makes 304 workharden instantly), make sure it's always either feeding forwards at the rate that produces a proper chip, or retracting.
    I bet you already knew that...
    But there are some subtleties that don't get mentioned so often:
    The critical moment is the first contact, needs to be positive, not tentative.
    Also centerpunching is best avoided. (Spot drill, as Randy suggests)
    If you do ever need to centerpunch materials prone to workhardening, it's a good idea to grind four facets (like a pyramid) on the tip of the punch, so the action is a combination of cleaving and displacement, and the first contact of the drill is with the least displaced (hence softest) material.
    Oct 2004
    St. Peters, MO
    2,965
    157
    140
    Post
    Troup,
    Very good pointers!! I will remember this for future reference.--Thanks!, Grant
