musicinabottle
- Sep 11, 2016
I have the arbor out of my table saw for bearing replacement. Old bearings were so tight on the shaft that I had to surgically destroy them of the shaft with a small grinder. Putting the first bearing on and about 1 inch on and it's ridiculously tight to the point that I'm beating on a socket slipped over the shaft on to the inner bearing race and I'm beginning to mushroom the top of the cheap socket. So operations have stopped! I'm contemplating chucking the shaft up in my drill press and holding something nice and square up to the shaft below the bearing with some 100 grit abrasive paper or........ would it be better advised to have someone work off a bit of material on a lathe? Fearful of destroying the shaft by getting it out of true, this being a critical component of high rpms. What to do?
