gavingear
- Apr 24, 2008
- Cashmere, Washington
I've got a bunch of 3/4" .095" wall mild steel square tubing that I need to cut 3/8" wide slots in. I did some with a 3/8" endmill, and it was both painful and slow. So, I've been experimenting with various techniques to cut this tubing. I was thinking to go with CNC laser, but that proved (via two local quotes) to be cost prohibitive.
So now I'm looking at using a slitting saw (a thin jeweler's saw) to cut the slots- two small cuts to cut out a strip of metal. I did a quick test on my vertical mill, and I found the material to cut quite well, but it looks like power feed will be needed (I was hand cranking my mill on the x-axis).
This is the kind of quality cut I'm looking for, requiring only minimal de-burring:
And here's the setup I was using for the test:
After running this test, I'm thinking that this job should be done with a horizontal milling setup (with a horizontal mill, or a vertical mill with horizontal milling attachment) with flood coolant, and with dual jeweler's saws spaced appropriately to cut a total of a 3/8" slot in one pass. With power feed, seems like it would go really fast, and the jewleler's saws seem to cut great, esp. if I can get .001" - .002" per tooth feed rate. I do realize this is an exacting setup, and shattering the thin (.020" - .040" wide) saw blades is a very real possibility.
Does this sound like a reasonable way to do this job? I'm assuming the jeweler's saws will cut much more cleanly than a 3/8" wide horizontal milling cutter or saw... Any other ideas? Feedback would be most appreciated.
Thanks!
Thanks!
