Dynamic Balancer DIY?
Results 1 to 10 of 10
    Feb 2009
    Maryville, IL
    131
    Default Dynamic Balancer DIY?
    I was wondering if there is a cheap software program that can be used on a laptop with accelerometers and strobes to balance wheels or pulleys. I don't know a thing about dynamically balancing except I saw a demonstration once of balancing a large pulley.
    Allen
    Dec 2000
    Bremerton WA USA
    10,615
    40
    3988
    Funny thing. This popped up on my first stab on Google:
    http://balancers.hypermart.net/precibalance.htm
    The next hurdle is the sensors and their interface with the computor. Maybe there's a USB analog to digital gizmo.
    Apr 2007
    Melbourne Australia
    1,262
    9
    10
    The sensors I have seen used are simple piezoelectric biomorphs (used as buzzers) attached to a compliant support for the part being balanced. No need for a computer, just amplify the signal and feed it to a comparator with adjustable trip point, use the comparator to drive a led or laser which illuminates the part.
    The biomorphs are AC response so they only register the imbalance.
    A computer could be used, accelerometers crop up on ebay and the like in the US at least and these would work also many commercial balancers just put 2 single axis accelerometers on pads fixed to the machine at 90 degrees along the axis of rotation..
    Dec 2000
    Bremerton WA USA
    10,615
    40
    3988
    I can see the reason for the computer. It's not just the magnitude and orientation of the unbalance that gets tricky. Determining the mass, radius, and axial placement of the correction in relation to the bearings is where a computer can be invaluable. Saves all that drilling here and there hoping for a miracle.
    I can make a Yakimoff balance out of old car parts and dial indicators and find the unbalance of rotating parts with trial weights and acres of graph paper - I think I can after 40 years since my last solo shot at it. I vote for a computer function that tells me where to correct.
    Dec 2005
    Germany
    630
    43
    Hello,
    the guys who built jet engines for models planes are the right ones to ask for advice here. A little work with google will surely yield results, I remember reading about balancing engine parts that run at 60.000rpm with a homemade mock up with good results.
    Cheers,
    Johann
    Aug 2008
    Californeeeah
    1,436
    40
    296
    I've never done it myself, but have looked into. Seems to me there was a big discussion about it on this site. Here's s/w that you can use to measure the signals, but it doesn't do the balance calculations:
    http://www.sillanumsoft.org/
    I hear that you can use a loudspeaker with a weight glued to the cone as a transducer. Here's all you ever wanted to know about dynamic balancing:
    http://www.reliabilityweb.com/fa/vibration.htm
    Feb 2005
    Birmingham, AL
    4,023
    12
    40
    Yes, calculating where the weight goes is the tricky part. Especially on more than one plane.
    Jun 2004
    Melbourne Australia
    5,062
    659
    1885
    Quote Originally Posted by Forestgnome View Post
    That was probably the Excel spread sheet that Conrad Hoffman wrote. That does all the calculations. The link is in the first post of this thread.
    http://www.practicalmachinist.com/vb/showthread.php?t=181139
    If you down load it, make sure to click on the second page tab of the Excell doc to see the calculation page.
    Regards Phil.
    Jun 2005
    Edmonton,Alberta,
    1,179
    138
    90
    Quote Originally Posted by Allen Hunt View Post
    Allen
    Allen,
    We were talking about that in another thread. I was quite interested in Andy Paul's solution at http://usbmicrobalance.com/index.html . I already had the acquisition boards and accelerometers and did do some balancing but it was not efficient since the I was guessing about the corrections.
    To save time I purchased his system which I found to be reasonably priced (everything is on his web site). Some people are even balancing turbo chargers with this. I have been delayed a bit by our bearing package therefore I have only done a bit of field balancing with it.
    You mention using a strobe - well he does much better than that with his laser sensor.
    Raymond
    Jul 2008
    People's Democratic Republic of Louisiana
    2,557
    562
    266
    http://www.turbinetraders.com/turbine177.htm
    http://www.turbinetraders.com/turbinechadwick192.htm
    http://www.turbinetraders.com/turbinestrobex.htm
    I bought these three items from a flight department that was closing down a year or so ago, for $1000.00. Heck of a deal.
    Half of the value was in the plotter. I've seen the basic balance/strobe kits go for $300.00 on ebay.
