Economy machnist level?
Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Apr 2009
    WI
    39
    Default Economy machnist level?
    Hello everyone, I was wondering if any of you have recommendations for a cheap-er but still respectable machinist level? Not really ready to dish out $150 for a brand new Starrett...
    Jan 2007
    Massachusetts
    5,105
    642
    1014
    I had got a really nice 6" Starrett No.98 (like new, in box) from a local guy who advertised on Craigslist....for $5.
    You won't be quite as lucky, but I'd try Ebay. Tons of them there.
    Or:
    F/S Flotsam & Jetsam from my cave
    Apr 2009
    WI
    39
    In buying a used one, does the bottom of the level need to be re-ground?
    May 2005
    AZ
    2,148
    179
    721
    Not unless the reference surface has been badly abused -- in which case you shouldn't buy it anyway. The important thing is to make sure that there are not high spots or corner dings, and to make sure that the level can be calibrated. If the level can be placed on a surface plate and all feels flat, no rocking, then as long as you calibrate the level for same reading when turned end for end, you should be good. A stone is usually good for cleaning up dings on the reference surface.
    May 2009
    Canandaigua, NY, USA
    2,394
    99
    903
    My 6" Starrett wasn't all that flat- I had to lap it to prevent rocking on a surface plate or my lathe bed. You might try the Grizzly H2683 from Amazon for $79.95. It's more sensitive and probably of sufficient quality. It's easy enough to check and calibrate a level.
    Jan 2007
    Massachusetts
    5,105
    642
    1014
    Sorry to hear that. I'd never seen a bad Starrett level that hadn't been dropped or otherwise abused. Those you can usually detect from a good look even before checking it on a known flat surface. I bought mine without checking because it looked so pristine, and it was fine.
    Jun 2005
    OH
    1,267
    Be careful there...I think Starrett #98's still have ground vials (as did all the old time levels like Lufkin etc.)....the imports today do not clearly state this. Maybe they have them...maybe not. Ground vials are vastly more accurate and sensitive. Look for it.
    May 2009
    Mays Landing, New Joisey
    570
    154
    139
    I bought one from Phase II plus. Well made, imported (did I really have to say that?) and accurate for cheap.
    About two weeks after I bought the level I found a Starret that belonged to my late father. Both check out equally accurate.
    Apr 2006
    Mendocino, CA
    335
    15
    Try getting a used one.
    This guy is great. I got a Starrett from him years ago, and it was a bargain.
    http://www.rowe-machinery.com/
    Jun 2006
    Spokane, WA
    561
    97
    FWIW, this weekend, I picked up a perfect Starrett 98-12" at an estate sale for less than $50. They were asking $65, but I threw it in a box with a bunch of other stuff and got a package deal.
    thnx, jack vines.
  11. #11
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,305
    391
    1839
    Quote Originally Posted by PackardV8 View Post
    A lot here say the Starrett 98 is not accurate enough it being only 0.005/10 inches, the #199 is 0.0005/10"..
    I have an 8" #98 and have used a European Kimex brand 0.03mm/metre level....I was forever chasing my tail with the Kimex when levelling a machine...
  12. #12
    Oct 2006
    williamsburg va
    7,886
    838
    1711
    I have purchased 2 Starrett master levels in pristine condition.One for me and one for work. These are the most expensive ones they make. Somehow,both these levels are a bit hollow on their scraped bottoms. I wonder why this is.
  13. #13
    Mar 2001
    Switzerland
    2,419
    2008
    993
    Quote Originally Posted by gwilson View Post
    My guess is that the level will work if a bit hollow but not at all if a bit convex. Over the years it will wear flat, and eventually convex which means it's time to scrape.
  14. #14
    Oct 2003
    East Peoria, IL, USA
    5,228
    289
    687
    SPI. i have this, it's very nice. simple, sturdy, compact.
    https://www.penntoolco.com/catalog/p...categoryID=699
  15. #15
    Jan 2009
    Israel
    124
    6
    Quote Originally Posted by dsergison View Post
    Which is made by EDA (Ducourret) France (the 114 model):
    http://www.ducourret.com/standardA.html
    It seems like a nice level and I think this is the level I'm also going to buy. I can get it here in Israel for about the same price (usually it's higher).
  16. #16
    Jun 2006
    Spokane, WA
    561
    97
    Can one of our scraping gurus give us fact as to what percentage of machinery surfaces on which a #199 would usually be used are flat in X and Y, as well as parallel and perpendicular to 0.0005/10" over their entire length?
    thnx, jack vines
  17. #17
    Oct 2003
    5,228
    289
    687
    Quote Originally Posted by avivz View Post
    yes, that particular level was discussed & reccomended here a few years back. that's why I bought it.
    to the posters question about how level do surfaces normaly get scraped.... I dont think for most do-it-yourselfers that you need to use the level as your main or only source of measurement. you scrape to FLAT. you measure with other methods to define perpindicuar paralell etc... I dont know of much reason to need to scrape to "level" directly. I used my levels to set the leveling feet on my lathe to make sure the bed wasnt twisted. I rarely used it when I was actually scraping parts. but i'm no pro.
  18. #18
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,810
    1162
    479
    Default Home brew?
    Just a thought but, could you make one?
    If you bent a long glass tube over a thin spacer in the middle of a other wise straight edge (to form tube with a very large radius). Bunged the ends and (almost) filled said tube with an appropriate liquid.
    Given that it would not have the an internal barrel shape that most bubble levels use, how would it perform as a level?
  19. #19
    Jan 2009
    Israel
    124
    6
    Talking about levels, can someone please explain what makes one vial more sensitive than the other?
  20. #20
    May 2009
    2,394
    99
    903
    I'd think the homebrew bent tube would work fine. Fill it with alcohol. One could also make a tall support with a plumb bob (plumbob? plum bob?) and a magnifier and scale at the bottom. Have to be pretty tall to see .0005/" though ;-)
