Basically brand new Jungheinrich EJE 120, still under warranty. Built in charger, just plug 'er in the wall outlet. When you plug it in, what is supposed to happen is green light flashes quickly if battery is low, then flashes slowly as charge builds up and then stops flashing when fully charged.
But mine is such that even at 25 volts (24 volt system) there is no light at all until it reaches about 26 volts, at which point light comes on slowing flashing. But hours later it is still slowly flashing. I checked voltage (with charger unplugged) and it was 27.25 volts. Shouldn't that be enough to be fully charged ?
My concern is that the flashing light will never stop flashing because the charger never stops charging and then ruins the battery (however even at that high voltage the battery was not warm to the touch) It is under warranty but the dealer's tech has to travel like 2 hours each way and I have this vision of the guy saying "what are you talking about...see, the light is flashing just fine" To which I would feel like saying...well, yeah, but come back in 5 hours and we'll see if the light is still flashing and the (very expensive) battery is cooked....
Thoughts ?
Thoughts ?
