Electrical runout?
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 87
    May 2005
    Alabama
    539
    38
    Default Electrical runout?
    I'm working on a 97" long 6" dia. shaft made out of 4150 steel for a big electric fan, one of the specs is for the bearing areas to have no more than .00025 Mechanical and Electrical runout, what is electrical runout and how is it measured, some kind of special instrument we don't have I imagine.
    Aug 2008
    Californeeeah
    1,442
    40
    296
    Might ask the question on this forum: http://maintenanceforums.com/eve/forums
    These guys know everything about machinery specs (not disrespecting anyone on this forum).
    Apr 2006
    Denmark
    402
    753
    71
    Could they mean axial displacement between fan shaft and motor shaft? Works out to slightly less than one hundreths of a millimeter which I find an exaggerated demand. Is there a coupling of some sort to allow displacement or is it just a very stiff connection? Just my .02 Euros.
    When you find out, please post. I'm intrigued!
    Regards, fusker
    Apr 2006
    Fort Worth, TX
    1,303
    25
    26
    I think it has something to do with the magnetic properties of the shaft.
    Jun 2001
    St Louis
    16,750
    1386
    2554
    I can think of several possible meanings, but none of them apply to the shaft alone. They would only apply to the shaft plus the rotor.
    I am supposing they refer to mechanical and electrical/magnetic balance, not just specifically runout.
    Aug 2007
    Spokane
    310
    I suppose it is possible that they don't know what they are talking about. Or don't know how to properly specify what they want. Or is that the same thing??
    Dave
    Nov 2005
    Maryland
    8,508
    741
    1059
    Quote Originally Posted by Cuda View Post
    what is electrical runout and how is it measured.
    Why don't you ask your customer?
    They're the folks who will test and accept or reject your work.
    - Leigh
    Nov 2004
    Canada
    1,765
    You need an electronic feeler gauge, but they are hard to come by
    Minder.
    Feb 2006
    Indiana
    11,953
    441
    3139
    The first question should be, what are the units? The .00025 could be inches, mm, feet, angstroms, farads, mmg or whatever.
    Larry
    Jan 2005
    Houston
    5,063
    305
    1943
    I deal with this every day - it sounds like you are looking at an API requirement as that tolerance is common in many of their rotating equipment specs. It's hard to meet. Or rather, it's hard to meet if you have to guarantee it. Sometimes you'll hit it, sometimes you won't.
    Generally the tolerance is applied to the area of the shaft where the Bently Nevada (or other type) proximity probes will read - any imperfections in this area will be picked up as vibration.
    Mechanical runout is just what it sounds like - non-concentricity of the shaft. Electrical runout is caused by irregularities in the shaft steel that will be 'seen' as non-concentricity.
  11. #11
    May 2005
    Alabama
    539
    38
    Quote Originally Posted by GregSY View Post
    Thank you, that's the answer I needed, so in other words there isn't really anything I can do about it, the print did show the areas where it would be checked and it said something about burnishing it there, would that improve the electrical run out? We have no burnishing tools. But then again this is an emergency replacement shaft, so they may not be so picky about it!!!
  12. #12
    Jun 2006
    Taylorsville Ky
    3,122
    23
    Who in the world dreams up these outlandist terms? Other than to drive you nuts figuring it out, does it really mean anything different than the normal terms of trueness or tolerance would mean?
    The term "Electrical Runout" for machining sounds ridiculous to me and after gregsy's explanation it still sounds ridiculous.
  13. #13
    Oct 2003
    Bonners Ferry, Id
    2,875
    572
    372
    To eliminate guessing,GOOGLE IT.
  14. #14
    Nov 2005
    Maryland
    8,508
    741
    1059
    Lightbulb
    One possibility is that they're referring to use of an electrical (electronic) profiling system.
    A device that measures capacitance can perform dimensional measurements with extremely high resolution and accuracy. The probe is placed very close to the work being measured, then the work is rotated on axis.
    Any change in the distance between the probe and the work is easily measured.
    - Leigh
  15. #15
    Dec 2005
    Jersey Shore
    3,818
    276
    450
    Could them be a translation problem, as eliptical rather than electrical?
  16. #16
    Nov 2004
    WI
    4,571
    366
    1010
    After reading that, it made perfect sense to me, and why the terminology is used.
    I'm interpreting it that the part may be subject to an electrical measurement for run-out/vibration. If the steel is non-uniform ( electrically) then the gauge will not readout correctly, and will not indicate run-out correctly.
    If the steel had various inconsistencies floating in it, it might be mechanically true, but will not readout correctly when measured electrically.
    But then again, I could be wrong.
  17. #17
    Nov 2005
    Maryland
    8,508
    741
    1059
    Quote Originally Posted by 3t3d View Post
    Sorry... not true.
    The capacitance between two conductive plates is solely a function of the overlapping area divided by the separation. No other factors are involved.
    In particular, the composition and homogeneity of the materials do not enter into the calculation, provided of course that they can conduct electricity.
    - Leigh
  18. #18
    Nov 2004
    WI
    4,571
    366
    1010
    Even for a magnetic probe?
  19. #19
    Jun 2006
    Taylorsville Ky
    3,122
    23
    Yep, google it here www.freepatentsonline.com/3986380.html
    After reading the whole looooong page I still don't know what purpose or effect electrical runout does or has but I know how it's found and corrected.
    I guess instead of the electric pencil you could use a chisel and hammer
    After reading the article it sounds like something Rube Goldberg would come up with.
  20. #20
    Sep 2006
    Abingdon, VA
    3,106
    3919
    2476
    Wow! Good luck on holding that kind of runout on a 97" long shaft.
