Electrical runout? - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 87
  1. #41
    Aug 2005
    Tucson AZ
    5,877
    7980
    2685
    Carl, if you make this shaft and measure, say, .0005 TIR, and the eddy current meter says that there is .002 TIR, then the difference is electrical run out. It is not real run out but the system can't tell the difference. Since most steel is pretty homogenous the usual source is variations in the surface finish. These can be eliminated by polishing and burnishing.
    Interestingly the spec called for this to be measured at the bearing areas. This meaningless because the sensor is not in the bearing area. It's next to it, as close as possible but may be a foot away.
    Bentley Nevada has most of the market for this stuff. The turbines I work on may have there sensors for temperature, radial and axial runout, axial growth, and speed. You might contact them for advice on preparing this surface.
  2. #42
    Jun 2006
    Taylorsville Ky
    3,122
    23
    Ok, tdmidget, that I understand, it's electrical in the sense it's read off a sensor and that's just as I thought.
    I guess it's the hard headed Dutch/German in me that seeked a reasonable answer.
    Actually it's Cuda that is seeking the info on electrical runout while I am trying to understand what electrical has to do with runout.
    Problem solved, thanks.
  3. #43
    Nov 2004
    WI
    4,571
    366
    1010
    Carl,
    Basically a dial indicator can detect if the surface of the shaft is smooth, and thus in your perspective, it has no runout.
    An electrical device can also measure the runout of a shaft, the BIG difference is that the electrical device can't JUST see the outside surface, ( that you are measuring with a dial indicator) the electrical device "sees" right into the steel itself. It can see any inconsistancies INSIDE the steel.
    Now in the ideal world, the sensor wouldn't see, or care about anything except the outside of the steel, like your dial indicator does.
    But in the real world, the sensor Does see the structure of the steel, under the surface and will get fooled into thinking it is seeing runout that is not there.
    The inconsistancies that your dial indicator cannot see, but the electrical device CAN see, are best labled as "electrical runout" because it is a "runout" in the sense that an Electrical device will be fooled by it.
    So, there is nothing "New Age" at all about the naming of the phenomonon.
  4. #44
    Jun 2006
    Taylorsville Ky
    3,122
    23
    Ok, I can buy the sensing internal mass but why can't they do a base line run and not have to burnish the metal? All the burnishing can do is affect the surface and a small depth of the metal.
    I see no need to require a surface burnish, can you explain why.
    We are getting close to the end now. If a base line reading will determine the "electric runout" without burnishing we are done and the patented process is a hoax.
  5. #45
    Feb 2004
    peekskill, NY
    23,684
    3878
    "electrical device "sees" right into the steel itself."
    Total crap.
    Steel is electrically conductive so as such, the surface forms a nearly
    perfect faraday shield and no electrostatic method can investigate
    any features below the surface.
    Either this is a) complete snake oil, or b) completely mis-named.
    I could imagine a *magnetic* sensor that measures features in the
    shaft's local magnetic field, that would suggest features in the
    body of the shaft.
    But now, that would be "magnetic runout" and not "electrical runout."
    Jim
  6. #46
    Sep 2005
    il.
    6,558
    29
    1175
    If you slow roll the shaft in a set of precision v blocks using a good dial indicator you can see the mechanical runout
    Ahaa!
    what about tri lobe?
    I'm sorry
    discussions like this are so far over my head i lost control when i got a chance to say something.
    we use to do a lot of centerless grinding and there is a phenomenon that makes a kind of triangle cross section that doesn't show in the v-bloke roll test.
    sorry
    please continue
  7. #47
    Aug 2007
    Spokane
    310
    Quote Originally Posted by GregSY View Post
    An accelerometer sense rate of change whereas a proximitor measures total movement, or amplitude. You could have something really moving a lot, but slowly, and the accelerometer wouldn't think much of it.
    Typically acceleromoters have to be mounted on a non-rotating piece such as a bearing housing. But since the shaft is what is moving, and presumably creating the vibration, you will have a lag in time before the force makes its way through the oil film and into the housing. There's of course also a reduction in the force as it makes its way to the accelerometer. By sensing actual shaft movement you have the most accurate data and the best chance of shutting down a machine before damage occurs. When you have a rotating component weighing thousands of pounds and spinning fast you have very little time to trip.
    There has been a push in the industry to have shaft acceleration (measured by prox probes and translated into 'inches per second' readings) looked at more closely but it doesn't seem to be gaining much favor. People still are more concerned with amplitude. There is a table in API which converts IPS readings to amplitude based on RPM for those who care.
    Accelerometers are usually used on slower speed pieces of equipment and equipment which is going to shake a lot anyway - think of a rock crusher or grinding mill.
    Carl - yes, that is exactly right. The shaft can have absolutley no mechanical runout at all and the probes will show that there is something going on. It will do so for two reasons:
    1) it will pick up vibration and report it
    2) it will pick up electrical runout and report it
    If you had a rotor in perfect balance (no vibration) and no mechnical runout, the probes would still sense the electrical runout and report it as 'movement'. It doesn't report it as 'runout' or 'vibration', it's all the same to the probe. The probes are not smart enough to know what they are reading, they just know it's there. That's why a customer wants to keep E&M runout to a minimum - that way they know their readings are as close to accurate as possible.
    Imagine a shaft that had no electrical or mechanical runout at all - whatever the probe reads would be actual vibration.
    This is all important because it's vibration, not runout, that is harmful to the equipment's life.
    For me this begs the question of why would we use a system which could possibly result in so much bad data and possibly so many "nuisance" (or worse) shut downs. As in your example of the shaft that has perfect balance and no mechanical runout but is still perceived as having "electrical runout", the probes being too stupid to know that there is nothing wrong.
    I can understand wanting to sense an out of balance or crack propagation event as soon as possible, but it seems pointless to monitor something that will be catastrophic in 1-10 revolutions when it would take 1000-100,000 revolutions to bring the whole shebang to a halt.
    Or maybe the reliability of this method is greater than is being represented so far in this discussion and my ignorance is showing again??
    Dave
  8. #48
    Nov 2004
    WI
    4,571
    366
    1010
    Quote Originally Posted by jim rozen View Post
    Total crap.
    Jim
    If you had followed this thread, you'd realize that the device in question is an electrical device, that is using eddy currents, not an electrostatic field.
    Now you can get all pedantic, and argumenative, (once again) or try to be helpful, and explain something in a manner that will be helpful to the person with the question.
    Are you suggesting that the eddy current device is hydraulically powered? No, it is electrically driven.
    Are you trying to be helpful, or not?
  9. #49
    Feb 2004
    peekskill, NY
    23,684
    3878
    It's NOT ELECTRICAL RUNOUT.
    Nothing ELECTRICAL is running out. No ELECTRICAL
    parameter in the shaft is being measured. No ELECTRICAL
    performance is being improved, modified, adjusted, or
    influenced here.
    Whoever invented that specification is a MORON and should
    go back to serving coffee at starbucks.
    You could use a federal gaging head which is ELECTRICAL
    to measure the physical runout on the shaft but that does
    make the resultant number an ELECTRICAL runout. No.
    You could sweep the OD with a wire hooked up to a light bulb
    and claim you were measuring an ELECTRICAL property of
    the shaft operation. You could do that and everyone would
    laugh at you for maintaining that position.
    Look, non-destructive testing is a huge industry issue and they
    do things like measure magnetic behavior of parts, and if you
    could invent a widget that you hold up to a steel shaft in
    motion and tell reliably that there's some sort of defect or
    non-uniformity in the shaft that can be improved, the folks
    in that discipline would kneel down and kiss the hem of your
    garment because such a thing, short of X-raying the part,
    to my knowledge simply does NOT EXIST at this time.
    So yes, I'm trying to help. I'm suggesting to the original poster
    that he watch out carefully because it looks like a bit of snake
    oil is being peddled here.
    Jim
  10. #50
    Jun 2006
    Taylorsville Ky
    3,122
    23
    wippin boy, I sure do like your avitar, he is cute. We have a little doll that has that pouting face and she is cute as hell. We call her Mary Lou our adopted daughter.
    Ok, back to the problem, thinking about it I am thinking it does not sense the irregular mass but just the vibration of the shaft due to the bearing play. Since they have to take a base line reading by rotating the shaft slowly in V blocks or in the bearings themselves.
    I went back and read several sites about electrical runout and none of them explain what electrical runout is. They describe how to detect it and how to burnish the shaft in the area of the sensor but that's all. Some say that it will detect vibration and/or movement in the shaft.
    So with that I am jumping back to my thought that all they are looking at is reading bearing wear to tell them when to replace the bearings before it goes WHAM BANG. They use an eddy current sensor or a capacitance sensor to sense the electrical runout.
    As far as I can tell the term "electrical runout" pertains to the use of electronics to determine when the shaft exceeds a certain vibration or mechanical runout and the area where the sensor runs has to be burnished to a smoothness to eliminate any electrical impulses in the sensor.
    EDIT: it seems I was composing and posting while Jim was and I totally agree with Jim after reading about 6 sites that described everything with great accolades but no where did they say what electrical runout is.
    All it is at best is an expensive glorified means to detect excessive radial and axial motion in a shaft with electronic apparatus.
    Problem solved.
  11. #51
    Jan 2005
    Houston
    5,063
    305
    1946
    Jim, I'm amazed that you know so much...I'd suggest you publish a paper and set the rotating equipment world on edge. You'll be a rich man. Do you really think that scores of PhD-level mechanical engineers with a combined total of thousands of years of experience would dream up the existence of electrical runout? I'll bet you have poured more coffee than they ever will. I have dealt with enough of the top engineers at the world's largest oil companies and they are astoundingly brilliant. Not only do they have the best educations, they also have decades of hands-on experience.
    The annual IEEE-PCIC conference is coming up in two weeks - man yof the people who wrote those specs will be there. I suggest you take the mike in front of a thousand people and tell them just why they are wrong.
    Carl, electrical runout has nothing do with electronics. It exists whether you can measure it or not. Or rather, the moment you endeavor to measure the vibration of a rotating shaft with a non-contact device (which pretty much will need to be electronic) electrical runout will appear.
    I think the main problem is you guys are thinking in terms of great quantities of electrical force, and it doesn't make sense to you that it could exist. In fact, we are talking about relatively minute amounts - but those small amounts matter because the monitoring devices are so sensitive.
    If something - anything - has molecules then it has electrical forces within it. It's not hard to reason that a 97" long alloy steel shaft will have some non-homogeneity. Some areas will have a little more of one component than the other - and they will have very slighly different electircal properties, as read by a probe, than others.
  12. #52
    Sep 2006
    Sacramento County, California
    3,275
    1784
    936
    Quote Originally Posted by Cuda View Post
    I'm working on a 97" long 6" dia. shaft made out of 4150 steel for a big electric fan, one of the specs is for the bearing areas to have no more than .00025 Mechanical and Electrical runout, what is electrical runout and how is it measured, some kind of special instrument we don't have I imagine.
    I have little to add regarding electrical runout and will accept what has been stated as a definition as true.
    Having said that, looking at the original post here from Cuda, let's assume that he does a perfect job of machining and the result is no mechanical runout. (0.0)
    Will that also guarantee that there will be no electrical runout? Put another way, is the electrical runout a result of mechanical runout or does it arise from some electrical quality in the piece of stock that Cuda chooses to machine independent of the machining?
    It would be a shame to have a perfectly machined piece rejected due to some hidden flaw within the metal itself. Then it would seem that the choice of material would be extremely important.
    Just curious since I willingly admit that I've never heard of electrical runout before.
  13. #53
    Feb 2004
    peekskill, NY
    23,684
    3878
    "It exists whether you can measure it or not."
    Er, I think we're getting close to the problem here....
    "If something - anything - has molecules then it has electrical forces within it. It's not hard to reason that a 97" long alloy steel shaft will have some non-homogeneity. Some areas will have a little more of one component than the other - and they will have very slighly different electircal properties, as read by a probe, than others."
    I will repeat this. I will put it in caps for emphasis. It is a basic element of physics.
    ONE CANNOT DETERMINE ANY INFORMATION ABOUT STRUCTURE INSIDE OF A
    CONDUCTIVE BODY, USING AN EXTERNALLY APPLIED ELECTRIC MEASUREMENT.
    This is farady's law. One cannot detect or influence charges inside a closed
    conductive surface.
    The. Shaft. Is. A. Closed. Conductive. Surface.
    No electric measurement can penetrate into the body of the shaft or give
    you any information about what is inside of it.
    Don't like that? Take it up with Mr. Faraday.
    Maybe the guys at this conference are real whiz-bang gizmo geniuses. Maybe the
    technique in question uses something beside an electric measurement. But if so
    they sure dropped the ball at naming it.
    Jim
  14. #54
    Sep 2006
    3,275
    1784
    936
    conductive surface.
    Jim
    Given that Mr. Faraday (and you as well) are correct, then it would seem that a machinist taking in a job where a specification exists, not only for mechanical runout but for electrical runout as well, would be taking a big chance on getting his work rejected for forces beyond his control. (no pun intended).
  15. #55
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    This might be useful information. "Electrically induced runout" is one of the "glitches" described.
    http://www.gepower.com/prod_serv/pro...ada/glitch.htm
  16. #56
    Jun 2006
    Taylorsville Ky
    3,122
    23
    That site said much the same as the others I have read.
    It all boils down the the fact that "Electrical Runout" is a term used to describe the use of a sensor to read any radial and axial runout or vibration in a shaft. It seems it is used mostly in highly balanced rotor/shaft assemblies.
    As Jim said, it has nothing to do with electricity in or around the shaft, nor the mass internal or external. It has to do with electronic sensing of the shafts movement.
    It does require a treatment of the shaft where it is work hardened and trued in the area where the sensor reads.
    Electrical runout is not what one would think it is, it is just mechanical runout measured electronically.
  17. #57
    Jun 2001
    St Louis
    16,753
    1387
    2555
    Jim Rozen is being extreme.... he, with his physics background, knows very well that the shaft is NOT a (perfectly) conducting surface.......
    That being the case, it has a 'skin depth" at any frequency, which represents the depth to which an outside signal can "see" or "be seen" in the material. It really is the effective depth to which current is induced in the surface.
    So, yes, the outside signal from the probe WILL 'see" into the material some distance. If the conductivity (resistance) varies, the induced currents will not be uniform all around, and "runout" will be indicated despite the fact that there isn't any real runout.
    All this crazy 'electrical runout" specification business means is essentially just teh following:
    "We don't want our probes to detect a baseline runout over XXX amount for any reason, whether the surface is bumpy, or the material is non-homogeneous, or whatever. To cover our butts, we spec this so we can use these probes without thinking, and not have to characterize every shaft individually".
    To be sure the runout is truly within spec, you'd have to test it with a similar probe with the shaft on centers, etc.
    And I agree the term "electrical runout" is misleading, bogus, etc. However, it also seems to be the standard industry term for the effect, so this might be a good time to get used to it.
  18. #58
    Feb 2004
    peekskill, NY
    23,684
    3878
    The skin depth, at any reasonable frequencies, will show that the conductivity
    for steel (which is of course much less than copper) is very very thin indeed.
    Probably a couple of microns at most. If you work the equations you find that
    the resisitivity can be pretty large, and the skin depth still quite small.
    Steel boxes make excellent faraday cages.
    Jim
  19. #59
    Nov 2004
    WI
    4,571
    366
    1010
    Jim
    And That is why a thin piece of steel will completely block a magnet!
    Yes, Jim I believe you now, I won't even try it to see if as magnet can attract anything if a thin piece of steel will block out the magnetic field. You must be right...
    Magnetic lines can't possibly penetrate steel to any depth can they?
    Are you REALLY trying to tell everyone that a Magnetic field is completely blocked by a thin layer of steel?
  20. #60
    Feb 2004
    peekskill, NY
    23,684
    3878
    So it's really MAGNETIC runout?
    Not ELECTRICAL runout?
    Which is it please. I mentioned above, magnetic
    methods are used often to do non-destructive testing
    of steel parts.
    But we're not talking about magnetic runout.
    The name of the game here is ELECTRICAL RUNOUT. Your phrase, not mine sir.
    My comments above still stand.
    The most recent paper on this I can find is that one from 1975. Does not seem
    to be much interest in this technique, aside from the guy who patented it,
    after that.
    Nobody seems to be able to say exactly what is being measured here, or
    exactly what the benefits are. Aside from the broad "it's really important"
    and "lots of folks use this" there's not much.
    Is it an electric measuremetn? Is it a magnetic measurement? Does it probe
    only the surface, or does it give infomation about the bulk properties? Is there
    any predictive value in it? How does the 'burnishing' mentioned in the abstract
    differ from simply shot-peening the surface to reduce crack propogation.
    How far in does it look? Does it work on non-ferrous materials? Why is there
    such a long discussion about reduction of overall magnetization in the measured
    parts?
    Lots of questions. Not many answers.
    Snake oil? Maybe. Anyone can get a patent. I've never seen this term used in
    industry. But then I'm probably too critical overall.
    Jim
