Carver2
- Apr 16, 2014
- Buffalo, MN
Hi all. Searched the site pretty hard but have been unsuccessful in finding a similar thread on the problem I'm having. Ok, here it goes. Been trying real hard to get my Dad's Mold shop up and running from having the doors shut 14 years ago. So with the help of all the information here on the site I've been able get everything up and running with the exception of one "Y" Axis on the Acu-Rite III DRO on the knee mill. First off, the DRO wouldn't zero out after switching it on. It only showed the Fault mark on all three axis. So after a bit of swapping parts I was able to determine the small capacitor on the power supply board was at fault. Guess the electrolyte lost it fizz. After replacing it from one I found at the local Radio Shack. Things were looking pretty good with the exception of when I connect the round 6 pin "Y" axis connector to the back of the DRO causing none of the axis to work. They all stay at "0" with no change when movement is applied. Basically it locks the readings on all axis. But when I disconnect the "Y" axis cable from the DRO, Z and X axis both work perfectly fine. I've pulled the "Y" axis reading head and cleaned both the glass scale and the reading head. Though I haven't been able to locate the correct "Temporary alignment Bracket" for actually being able to square the head up and final the install. so if anyone out there has one they can borrow me or has measurements they can share I would be more then appreciative. Anyway, I thought I might throw this out there and see if anyone has had this type of issue and was willing to share some insight on what my problem might be.
Also, I've checked continuity from the Reading head board to the pin on the cable. All 5 wires check out fine. One thing I did notice was that the ball spring on the reading head appeared to be rubbing on the circuitry on the board. Does anyone know if this is normal? Is it possible for the ball spring to be shorting out the system and causing this type of problem.
Again, Thank you for all the information that has gotten me this far.
Ri
Ri
