rich p
Cast Iron
- Sep 7, 2003
- plantsville ct. usa
Hey guys, we have a tube swaging machine at work that basically uses an electric drill that drives a tool that swages a fitting on the end of a tube. We run 120 volts to a box that feeds the drill. We preset the box to a torque value that is spec'ed to the particular job, which then cuts voltage to the drill when the torque setting is achieved. Problem I have is I need to certify that the controller is cutting out at the right time. All the calibration houses I know of say they can't do it. I believe the drill needs to be there for any calibration so the amps can be measured. Has anyone had a similar problem or know of a place that can yearly calibrate this thing?
Here's a link to the controller
ELC11 Electric Torque Controller
