Hello guys,
we have an M5x0,8 bolt and nut that are going to be zinc plated with a nominal thickness of 8µm. What tolerances should I use? I read that the allowance should be 4 times the plate thickness, but on the female thread the G tolerances allowance is only 24µm. Or should I sum the female and male thread allowances (for example: G=24µm, e=60µm) and this two together should be more than 2*4*8µm?
I hope you understand what I'm trying to say. Thanks for the help.
