SeymourDumore
- Aug 2, 2005
- CT
Guys, a technical question: What does electropolishing do to a surface that cannot be reproduced in any other way?
I kinda-sorta know what it does and how it does it ( though surely ready to be educated in detail, even deep detail ), but the question really
is in the realm of why it might be specified EXPLICITLY as a surface finish?
Take the very case in hand ( in my hand right now ):
Part is a 3.00 dia x .87 thick disk. One surface is drilled/tapped 3 x 1/4-20 .500 max, do not break through.
The other side is plane-jane flat.
There are no thickness, flatness or parallel callouts whatsoever, tolerances are wide open at +/-.01 UOS.
And yet!
The flat face ( only the untapped face ) and the OD is specified as:
I mean I can grind and then flat-lap the face to w/in .0001 if needed.
I can grind and polish the OD if needed.
I can make them mirror in every sense of the way ( have granite plates if needed for the 15" Lapmaster ) mechanically.
But, I do have to go with what the print says, and I will.
So the question is simply rhetorical and educational: What does the electro polish process do to a surface which cannot be achieved in another way?
And yet!
Glass bead blast and electro polish these areas RA 1.6.
