clarnibass
- Dec 23, 2015
Hi
I've been checking the local 2nd hand websites for the last couple of years and finally a lathe that fits me came along... an Emco V10P. It actually doesn't fit here, but if I reorganize the space as much as possible then it does... just barely.
I'm not sure if there are any similar size/weight lathes, new or used, that would fit. A new Wabeco would but in spite of many very good reviews I see more than a few bad too (mainly electronic parts need replacing... expensive once the warranty expires). It has the very nice cam-lock, but no auto gear box (though that has a twist on the Emco, and a nice bonus rather than a critical feature).
This V10P has a weird combination of metric tail, compound and cross slide, with inch gearbox and lead screw. Apparently that was common in my country because... who knows.
It's supposedly in as good condition as you could expect, except a never used one. Bought new by someone who worked only on plastic and wood, nothing heavy duty (for its size), then bought by the current owner which used it very little.
It has the milling column which I'm not sure I'd use, but maybe.
It's originally 3-phase (which I have here) but was converted to 1-phase with a VFD and using the gears is possible (I think). There's a problem using it with the original 3-phase.
It comes with a 3-jaw chuck (inside and outside jaws), steady rest, milling column, inch and metric change gears, several QC tool holders.
"Slow" 3-nut chuck mount.
Inch QCGB is not that far from not having one since I do 90% metric threads, but I do 90% of those with dies anyway
To give an idea of what I do, usually light duty with wood, plastic, brass. Occasionally steel and silver steel, usually small diameters and cuts. I use almost only HSS tools and occasionally brzed carbide. I don't use insert tools at all. The lathe is important for my work but I use it very little, maybe a few hours a week on average, usually less (some weeks I don't use it at all).
The price is very high, but a few hundreds less than a Wabeco lathe without the cam-lock chuck or any accessories and before shipping and 20% VAT...
Should I run... towards it? Away from it? Is there any other model that is even similar?
Thanks!
Thanks!
