End mill recommendations for Aluminum
Results 1 to 16 of 16
    Apr 2009
    California, USA
    43
    Default End mill recommendations for Aluminum
    I guess I should preface this by saying I am a learning hobbyist and not a professional so I am seeking some guidance. I am working on learning CNC machining and am starting to get a handle on some of the simpler things. One thing I seem to be struggling a bit with is end mills. I have been shopping around and trying a variety of end mills just to see what works and what doesn't. I have done the Enco cheap HSS import mills only to find that they break surprisingly easy. I have had better luck with their Putnam end mills which seem to work fairly decent but I am looking for a bit more. For now, I am only working in Aluminum so that is what I am shopping for. I am running a 3HP knee mill based CNC machine set up to run 6K rpm with flood coolant.
    First, for the learner, what is a good end mill (what brand) to use that will produce a good surface finish while being fairly forgiving of a newbies ham fisted techniques?
    Should I stick with HSS or will I gain much by switching to carbide?
    Anyone have any other words of wisdom?
    Oct 2008
    CHRISTMAS ISLAND
    2,337
    747
    553
    Stick with a quality HSS 2 flute and you'll do fine.
    If you want to try carbide, I like SGS Ski-Carb. They produce the best side cut finish I've seen and are durable. The down side is they cost $$.
    Browse the MSC Big Book
    I typically buy from McMaster-Carr just because it's easier for me at work to do that and they do carry quality cutting tools.
    McMaster-Carr
    Tom
    Jan 2005
    CANADA
    Saskatchewan
    9,295
    1088
    3067
    Look for high helix endmills for aluminum. Even in HSS, these work pretty good, because they are very sharp, have lots of flute space to hold the chips and eject the chips well. You do need to be diligent with coolant application and get the chips out of the cut because they can plug up quickly and break off.
    In solid carbide, I really like the YG carbide endmills. They are available in high helix polished flute. The extra stiffness of solid carbide is a plus for more accurate machining.
    Maritool also has a high helix endmill for aluminum. Shop and compare pricing.
    Jan 2005
    The Netherlands
    5,233
    213
    1171
    I did have a single flute endmill once
    Wierd thing but worked perfect on aluminium
    Peter from Holland
    Jun 2006
    Huntsville Alabama
    1,775
    1019
    673
    If your just doing hobby work, I would stick with a 2 or 3 flute QUALITY HSS E.M. Lots of good brands out there.
    I'm doin production in a VMC here -I stick with GARR solid carbide endmills.
    Aug 2008
    Californeeeah
    1,437
    40
    296
    Use a hogging mil for material removal. Cuts like butter. Then use the two flute for finishing.
    Apr 2009
    California, USA
    43
    Any specific brand recomendations?
    Mar 2002
    Brisbane, CA, USA
    1,671
    73
    191
    Since you can spin to 6000 rpm, I'd say its worth it to go through the learning curve with carbide endmills. You need to climb mill, dwells are a no-no, use at least an air blast to minimize chip re-cutting and don't try to take cuts of less than 0.010" or so, at least on steel.
    An advantage of carbide endmills, especially when starting out, is that if you have a bad crash you'll tend to snap the endmill off clean while often an HSS endmill will typically do more damage before your hand finds the big red button.
    You can get good deals on carbide endmills from Tool Holders, Collets, Retention Knobs, Cutting Tools, Indexable Tooling and Machine Accessories - MariTool . He has special endmills for both aluminum and steel, and if you are cutting steel definitely get some of the vari-flute endmills, on low HP and not so rigid machines they make machining steel much easier. I also like the vari-flute endmills for aluminum from LakeShore Carbide.com Carbide End Mills-Carbide Thread Mills, but the Maritool endmills have been working well for me on aluminum also and are cheaper. Both these companies offer excellent pre and post sales support, so call them if you have any questions about which endmill would be best for you.
    Remember that with carbide you can wear it out faster by cutting too slow than by cutting aggressively.
    If you don't have coolant, on steel you will need at least an air blast nozzle, and if you plan to do a lot of aluminum I'd go with Trico Micro-Drop or one of the Acculube systems. These use a combined air blast with "micro-drops" of a special cutting fluid, but they don't make a big coolant mess or a nasty mist and they are a good match your type and size machine. Search on "Trico" and "Acculube" in the CNC forum and you'll hit more discussion on those units.
    EDIT - wow, I really don't like the new "feature" in this forum that automatically expands some website names into "slogans" for the website. In the post above I listed www DOT maritool DOT com, but the forum now automatically expands that into a long sloganized link for that website. It looks like you're trying to shill for that company rather than just simply mention them as a source.
    Milacron, if that's generating additional revenue for you I guess you have to leave it on, but if its not I'd get rid of it, the concept of doing "automatic editing" on a post someone has written is not such a hot one.
    Actually I also think it may be doing more harm than good in terms of generating click throughs for the listed sites. The automatically expanded slogans don't grab your eye that well as being a clickable link, versus the listing of a website name which definitely grabs your eye as a website location.
    Good luck-
    Paul T.
    Mar 2009
    Washington
    8,374
    5772
    10132
    Why can't you take small cuts?
    Mar 2009
    Washington
    8,374
    5772
    10132
  11. #11
    Jul 2013
    USA
    117
    8
    11
    I love using YG1 3 flute alu-power. They work great and cost is very low compared to any other carbide. I get mine from Marshall Tool in Seattle. Ask for Brian
  12. #12
    Feb 2005
    8,205
    11101
    9114
    Quote Originally Posted by John Welden View Post
    Because carbide is dull..... I thought everybody knew that... Dumbass...
  13. Likes John Welden liked this post
  14. #13
    Feb 2005
    8,205
    11101
    9114
    I completely disagree with this statement. The only reason to use an airblast is to get the chips out of the way so you don't re cut them.
  15. #14
    Feb 2014
    Sunny South West Florida, USA
    2,160
    8792
    2540
    Hmmm.... BSH21Wash... resurrecting a 4 year old thread to tell someone to buy something from someone named Brian in Washington (BshWash?)....
    If it looks like a turd, and smells like a turd....
  16. Likes Fitznoodle liked this post
  17. #15
    Jan 2007
    Norfolk, UK
    16,686
    12326
    11799
    Quote Originally Posted by TeachMePlease View Post
    Now didn't I always say you was a good bloke - well smelt out http://www.practicalmachinist.com/vb...archid=2820601
  18. #16
    Aug 2011
    Fiddlefart, Oregon
    1,656
    499
    676
    My 3HP knee mill does great with the Alu-Power carbide EM's. I don't know their limit, but I just got done doing a bunch of slotting where I'd plunge through the .550" thick part then cut the slot at full DOC. 3000 rpm with an air blast and alternating A9 and WD-40 (just once per slot) to stop chip weld. This on a rotab. Like them a lot.
    Edit: I see now it's a zombie thread. D'oh.
