Boat engine
- Dec 20, 2016
Hi all, first post.
I just had my boat engine rebuilt by an experienced machinist that's been building race engines etc for 40 years. So I'm not doubting what he told me just wanted other opinions.
It's a mercruiser 470. So lower by merc and head is a 460 Ford. Block is aluminum, head is a regular 460 iron. So it's essentially half a big block.
There is a nick on the block where head sits on block- couldn't be tigged or shaved any more. It isn't near the cylinders. It's a thin area of metal along side where the lifter holes are. I'll attach a picture later if needed.
My machinist said just clean it really good and use a little RTV, and I'll never had a problem. He knows what's he's doing and is probably right.
But I really don't like RTV. I have even had bad luck with it sealing oil pans.
So I'm wondering would I be better off using a dab of "the right stuff" by permatex? It's a lot stickier and seems more permanent than RTV. And more flexible which would make it more permanent in my opinion anyways.
The height of the gouge is about 1/8th" deep at the most, and the metal area width wise is 1/8" to 3/16" across. I can get more accurate reading later if needed, but it's pretty small chunk.
Thanks all
Thanks all
