Expanding Roll Core Spindle - What are they called?
Results 1 to 11 of 11
    Jul 2014
    Ontario, Canada
    836
    620
    547
    Default Expanding Roll Core Spindle - What are they called?
    What is the correct name for a mandrel that expands to mount a cardboard roll, such as a label roll, on a winder/unwinder? They look like they're extruded aluminium with a conical core of some type to allow for expansion.
    This company calls them "leaf shafts", which doesn't help me. The Guru of Motion would likely know but this isn't a shop management query per se.
    Mar 2006
    jacksonville,fl.
    846
    616
    256
    We use them on our window machines to hold the window film rolls.Sometimes called an air chuck,air shaft.
    Should have an air fitting to expand the bladder inside.
    Look at the manufacturers website.
    Dec 2003
    Washington
    4,377
    1899
    3385
    Double E company . . .Double E Home
    Jul 2014
    Ontario, Canada
    836
    620
    547
    Thank you both for your replies. As Ratbldr alluded to, and Guru referenced with the website, they're called "expanding core shafts". Specifically, the one I was looking at is a differential rewinding core shaft (not pictured in the OP).
    Mar 2009
    Brunswick Oh USA
    4,185
    4066
    2445
    The reason they call them leaf shafts, is because each segment is called a leaf. I've repaired a bunch of Comco and Tidland, but never a Convertech.
    Jan 2007
    wales.uk
    999
    52
    102
    I just call them expanding mandrels, there's a mechanical version too,
    Mark
    Oct 2005
    erie,pa
    8,353
    15211
    4062
    Quote Originally Posted by motion guru View Post
    "Everything you ever wanted to know about TP, but where afraid to ask."...
    Jul 2014
    Ontario, Canada
    836
    620
    547
    Indeed, many applications but I'm concerned with plastic roll re-winding. Apparently there's quite an art to, what one would assume is the simple operation of, re-winding plastic film onto smaller rolls after slitting. Due to variations in film thickness, each roll must wind at a different torque at different times in the rolling process. This requirement gives rise to a number of convoluted designs for shafting that allow varying speed among multiple rolls on the same shaft, and attenuates the torque of each.
    Oct 2005
    erie,pa
    8,353
    15211
    4062
    Quote Originally Posted by RC Mech View Post
    Yes, the take up reels on the tape machines (radio station I worked
    at) had "Torque motors", but would really like to see how they
    accomplish it with multiple reels on one common shaft.
    Jul 2014
    Ontario, Canada
    836
    620
    547
    This page from the Double E website explains the issue and their solutions quite well:
    Double E Home
    This is the differential rewinder page, just click "Product Info" next to Summary and scroll down for the "Differential Rewind Problem" explanation.
  11. Likes digger doug liked this post
  12. #11
    Dec 2003
    Washington
    4,377
    1899
    3385
    We buy a lot of carbon fiber rolls for paper converting upgrades (mostly bath tissue and kitchen towel lines where we want very light /low inertia rolls for measuring tension) . . . Epoch was our go to supplier and they were purchased by Double E. They are a quality supplier.
  13. Likes RC Mech liked this post
