Hi –
I have been doing a little experimenting with a home brew paint stripper made from a 10% mixture of sodium hydroxide (a.k.a. lye, caustic soda) and water. Basically 1 gallon of water and 1 pound of lye. To the 10% solution I added a bit of corn starch and mixed that in until the consistency was a gel so it would cling to vertical surfaces.
I swabbed some onto a vertical cast iron surface that has paint and primer residue and has been difficult to get off the rough cast surface. There were a few voids in the cast iron in the test patch that held paint as well. I covered the test patch with plastic food wrap to keep it from evaporating, and then left it overnight – probably 12-14 hours.
When I came back, the patch had a distinct reddish color to it, but scrubbing a little with some water and a brass detail brush, sure enough the paint and primer, even in the little casting voids, was all liquefied and came off very easily. A bit more water, scrub, then a squirt of acetone and wipe, and it was dry. However, there was a distinct yellowish tint to the area that was covered in the stripper. It looks like the aqueous solution of lye had started to rust the cast iron during the stripping process. The edges of the patch were well defined .
Other than this rusting, this paint stripping technique is the most effective I have ever used. It does not stink at all, cleans off easy enough, and liquefies the paint residue so that it flushes out of the voids. Sodium Hydroxide is of course dangerous if any gets on you, and you will most likely be blinded with a very small amount in your eyes, so one has to suit up properly.
Is anyone aware of refinement techniques to what I have done to minimize or prevent the rusting while it’s stripping? The temperature I was doing all this at was slightly below room temperature – nothing was heated. I have heard of tanks of this stuff being used to submerge items in, some heated some not so I am not sure if a warm/hot solution would be any different.
Thanks for any input.
Lewis
Lewis
