toolmonger
- Jan 29, 2011
- California, USA
About a year ago I started noticing poor results from our CNC tool grinder, primarily showing up in the od relief grind finish of end mills. The grinding between the primary and secondary relief was somewhat wavy. Video inspection showed peaks and valleys of .0002-.0008. The odd part was it was not consistent in when it was happening or how close together the waves were on the part being ground. I found that the slower I ran the program, the closer the waves were to each other. In addition, at first it was an intermittent problem and more recently has gotten much more regular.
After a visit from the factory rep, we somewhat ruled out the machine as being the problem. In the end, I have discovered that the quickly expanding industrial laundry next door installed a new machine about 20' away from this machine and that machine is vibrating the concrete floor, causing the problems. I am fairly certain this is the culprit, because having a water bottle sitting on my grinder when that machine is running shows distinct vibrations in the water. When that machine is off, the water is very still.
The machine's cast iron base is approximately 3' x 3', with 2 6x6 plates in the front and one 6x6 plate in the back which sit directly on the concrete floor. A bolt in the machine base centers the plate and provides adjustment. I recently purchased three 1" x 7" hard felt/rubber vibration pads and we installed them this week. We simply raised the machine and slid the pads under the steel plates. After leveling the machine I have tried it out, and it appears to have solved the initial problem. No more wavy grinds, even when that dryer is running. However, it has causing a different problem, and that is the machine now seems unstable. When rapid traversing of any kind happens, that whole machine shakes, or somewhat wobbles on the pads. It does stop before any grinding would happen, but it has me worried about what problems that side to side movement may be doing. I also see this movement when the machine is probing.
Sorry to be so long winded before asking a question.....
I am wondering if I used the wrong vibration pads? It is now occurring to me that maybe one large pad (3' x 3') would have been more stable. The other option is to move this machine as far away from that vibration source as possible and go back to just the steel plates. This is not an easy option in my situation due to the layout of our shop.
Is there a way to measure vibration in a floor? If so, does anyone know an acceptable limit of vibration for this type of operation?
Mike
Mike
