Hello!
I need to ream a hole that starts at z-20 (the first 20mm are already opened to a bigger diameter with a bigger drill bit) but I would like the reamer to travel back to Z5 each time instead of the beginning of the smaller hole (Z-20).
My lines are:
G0 X0
G0 Z-20
G98 G83 Z-40 Q1000 P2000 F0.05
G0Z5
This way the reamer does start at Z-20 but doesn’t go back to Z5 each time.
If I use G99 and add an R line the lathe does retract to Z5 but feeds at F0.05 FROM Z5 up to its next depth.
What I would like to do is to go rapid to Z5, then rapid to the previous max depth, feed for an additional mm, rapid at Z5, rapid at the new max depth, feed again and so on.
It doesn’t seem to be a way to do that, any clue?
Thanks a lot!
Tony
Inviato dal mio iPhone utilizzando Tapatalk Pro
My lines are:
G0 X0
G0 Z-20
G0Z5
Thanks a lot!
Tony
