Hot_wrench
- May 26, 2005
- Seattle
I have an older (50's) Yale 4k lift with basic hydraulics - lift and tilt. Everything works fine except for a very loud buzzing sound when the revs are above about 2000 rpm. It is coming from the valve assembly. The threshold rpm decreases in cold weather and increases in hot weather. It does not go away when the hydraulics are operated but it does change pitch (lower) and intensity (also lower). Additionally, once the noise begins, it does not subside until the revs fall below about 1000.
So far, I've checked the fluid level and the pressure relief valve. I have increased and decreased the spring pressure on the relief valve with no discernible change.
I'm tempted to open up the valve assembly but having limited hydraulics experience and given the age of the machine (parts availability and having to deal with the dealer), I'm a bit leery. What else should I check? Anybody ever had a similar problem? Thanks.
-Chris
-Chris
