Cory
Cast Iron
- Feb 9, 2007
- Sterling,VA
I am finishing up a restoration of a Barber Colman #3 gear hobber and want to use the best all around cutting fluid for gear cutting. I bought this gear machine to make gears to fix my tools. I called RPI and they recomended using Mobilmet Omega as an all around cutting fluid. I plan on cutting bronze worm gears and latter may be some steel spur gears but do want to change the fluid all the time back and forth. Can you guys recomend an all around fluid for gear hobbing.Thanks,Cory
