Firefox search engine and McMaster-Carr
In firefox one can highlight a passage of text, then right click on it and produce a google search or one of many search engines. There is a selection of search engine add ons at https://addons.mozilla.org/en-US/fir...:all?sort=name
Is there anyway to add a McMaster-Carr search engine so it exhibits the same behavior, only using the McMaster Carr "find products" field?
I can see me doing that with certain items, highlighting a key word, and doing a McMaster-Carr search by simple right clicking and pulling down a menu.
Would this be something that McMaster would prompt Firefox/mozilla to do, or can someone with only g-code & some ancient FORTRAN experience configure Firefox to do this?
Reason: spelling/typo/grammar
Keith,
I seems like that would be a Firefox plugin authored by McMaster Carr. you might plead your case to them.
Chip
McMaster has the best Ecommerce web site on the planet. Best built in search by far. I wouldn't be surprised if they would make a firefox plugin.
Well... it was just too intriguing so I wrote one, and it works.
one mo...
-DU-
I figured since Mozilla/Firefox is Open Source Software (OSS) it should be possible to find out how to write one. And it is....
I followed the instructions on this page (liked from the plugins page).
And in a few minutes with a text editor I came up with this:
Code:
<OpenSearchDescription xmlns="http://a9.com/-/spec/opensearch/1.1/"
xmlns:moz="http://www.mozilla.org/2006/browser/search/">
<ShortName>McMaster-Carr</ShortName>
<Description>Searches McMaster-Carr for stuff</Description>
<InputEncoding>UTF-8</InputEncoding>
<Image width="16" height="16" type="image/x-icon">http://www.mcmaster.com/gfx/products_catalog_115.gif</Image>
<Url type="text/html" method="GET" template="http://www.mcmaster.com/#{searchTerms}">
</Url>
<Url type="application/x-suggestions+json" template="suggestionURL"/>
<moz:SearchForm>http://www.mcmaster.com</moz:SearchForm>
</OpenSearchDescription>
Which I saved as McMaster-Carr.xml and then copied it to my
/home/utidjian/.mozilla/firefox/6r872f7x.default/searchplugins/
folder.
I am using Linux and if you are also the utidjian sub-folder name and the 6r872f7x.default sub-folder names will be different on your Linux system.
It should also work for Firefox in Windows but I don't know yet where Windows puts search plugins for Firefox. I will find out.
It may or may not work in Windows IE7. There are some caveats on the instructions page linked to above. If someone can rewrite it to work in IE7 that would be cool.
The icon comes out a bit mangled. I couldn't find a proper favico.ico icon on the McMaster site though there presumably is one. If anyone findsor makes a better icon please post it here.
The usual disclaimers apply. The above .xml file works for me. Your mileage may vary. As with all OSS code there is no warranty and if you break it or it breaks something of yours you get to keep all the pieces
-DU-
Hi David,
Default location for Windows XP Pro: C:\Program Files\Mozilla Firefox\searchplugins
Can't speak for other versions of windoze.
- Leigh
Thanks Leigh.
I will go and test it as soon as I find a machine around here that boots Windows. I know I have one somewhere...
-DU-
Leigh,
Found a Windows XP box.
Version:
Microsoft Windows XP
Professional
Version 2002
Service Pack 3
Firefox
Version:
Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.0.10) Gecko/2009042316 Firefox/3.0.10
Which I guess means version 3.0.10
And yes the file works. I don't get any little icon at all, just a blank sheet of paper with the corner turned up... but then PM shows up the same way in tabs.
I used the exact file as listed in my previous post, pasted it into Notepad, saved as McMaster-Carr.xml (ANSI format) and copied into
re-started Firefox and then did a search for "screws". Works fine.
Thanks again Leigh
Oh and the PM icons... well I know how much you are (smitten) by them
-DU-
Thanks DU, that is what I was looking for.
Unfortunately, I'm using an Apple running OS X. (Normally, I'd say "fortunately" but in this case I'm having some trouble).
I've tried to do the same, putting an .xml file in my searchplugins folder.
It doesn't seem to work for me, I'm still trying to figure out why.
On your box, you get a choice of search engine in the search box? You can now select McMaster-Carr from that menu?
Thanks again, stuff like this makes this board awesome.
Awesome. Works like I want it to
DU, everyone else, thanks. I hope some of you guys use it.
Here was apparently the problem:
I opened up a pre-existing search engine file, and noticed that it had a particular font (or lack thereof) in the text editor. When I originally saved the file, I selected .xml from a pull-down menu and it saved a file that when opened, had a different font. Apparently the default behavior of TextEdit is rich text format (RTF) and it seemed to save it in that format as well, but I'm not really familiar with .xml so I didn't exactly know. I went into preferences and selected plain text as the default new document format. I then saved the DU's code verbatim into the document, saved it as .xml by typing .xml at the end of the filename, and hit save.
Restart firefox and ta-da! McMaster Carr, just a right click away!
Go OSS (Open Source Software)
Edit:
PS, this also killed two birds with one stone. I did not like the fact that TextEdit's default behavior was RTF. I could save as a .txt file from a pull down menu, but now I'm much happier with TextEdit as well.
Keith,
Good you got it sorted out. I didn't try it on Mac OS X even though most of the computers here are Macs. I install Linux (Fedora 10) on most of them and dual boot.
The last couple of stanzas may be superfluous:
Code:
Not sure if those are needed.
I used gedit (gnome editor) to edit this code. I usually use vi in a terminal on both Mac and Linux.
Perry,
That is cool. There is also a link off of the link I gave earlier for setting it up on the server (McMaster-Carr) that allows the user to add the feature from the server site. Perhaps we can get Milacron to do that and then have a PM search option "built in" to our browsers (hmmm... )
-DU-
Thanks again Leigh
You're quite welcome, Dave.
Glad it worked.
- Leigh
I joined to post this. I took your code and added the icon to it. The favicon for mcmaster was located at www.mcmaster.com/favicon.ico
I converted it to base 64 data(which is what you need for the icon to be carried within the xml file. Everything works good now. I posted the xml file on my website so if people want it they can just download it and drop it into C:\Program Files\Mozilla Firefox\searchplugins
You can download the xml file here http://www.robogreg.com/wp-content/u...6/mcmaster.xml
Just curious but HTH did you get cued to the discussion in the first place? Been lurking a while?
I swear I tried that first and it only came up with what looked like a blank sheet of paper (or something). Perhaps I misspelled favicon.ico.
Thanks gneedel.
Only potential problem I can see is the filename may have to match the ShortName. McMaster-Carr =/= mcmaster. It may barf on some systems. I will try it on Mac OS X, Linux and Windows when I get to work.
-DU-
-DU-
I have been to the site before but don't read it actively. One of my friends IMed me last night saying he found the mcmaster firefox search. I wasn't there and he didn't provide a link so a quick google search lead me to this tread. I plan on sticking around though if people don't mind too much
When I get home I might try making some more of these searches for MSC, Digikey, and a few others I know i would like. Thanks for the thread.
Greg
Thanks Greg.
Now I have McMaster search engine icon goodness. Now it seems just as polished and finished as the others.
Google is just an internet version of McMaster Carr search.
Pretty soon I'll be "I mcmastered this last night..." and "I mcmastered that the other day..."
I have a fix for the missing/generic icon for those of you interested:
The new XML file is as follows:
Code:
<Description>Searches McMaster-Carr</Description>
<Image width="16" height="16">data:image/x-icon;base64,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</Image>
</Url>
David, thanks for your original submission on this to get things started. I have really never used the search feature that much. Rather I use the bookmarks toolbar and new tabs all day long.
Great work, Guys. I wrestled with that icon for a couple of hours and only managed to botch my cache pages for McMaster.
Excellent search addition.....and it now looks factory.
- You may not post replies
- You may not edit your posts
Forum Rules
