Still in my quest to make the perfect hole, I end up buying a lathe Grizzly G0602 now I need to learn how to use it, just finished doing the break in now I am waiting for the oils from ENCO didn't know it need it specialized oil, is a pain to find Mobil Vactra No 2 and Mobil DTE Heavy/Medium where do you guys look for this stuff locally?
I want to make a 2.1mm hole with a smooth inside surface with no tool marks in stainless steel, the holes is straight through 27mm long.
On a past post some people gave me suggestions in how to do this, the first suggestion to try is going to be a reamer so I am guessing I drill the hole at 2mm and ream it at 2.1mm, sounds right?
here is my question should I use a floating reamer holder? Is this a must? If so what floating holder do you folks recommend? Also I know there is many different drill bits what type of drill bit do you folks think I should be using? And could you guys please give me suggestions in where to buy this items. Thank you.
