JasonPAtkins
Hot Rolled
- Sep 30, 2010
- Guinea-Bissau, West Africa
Hi all,
The results of a recent thread about parting chatter on my lathe have encouraged me to bump up a toolpost upgrade I'd been procrastinating on. I'm replacing a BXA sized Phase II wedge QCTP with a CXA sized Dorian on my Colchester Mk1.5 15x48. The Dorian didn't come with a t-bolt, which doesn't look like too big a project, and shipping one here would be expensive. It will be a good example project for my students anyway. I know that the Dorian official one is a 3/4-16 thread. The only question left in my mind is to figure out how much slop there should be between the unthreaded shaft and the ID of the toolpost bore. In the case of the Phase II, it's .020" (the bore is .010" over the nominal 5/8" and the shaft .010" under). Before I recreate this (possibly bad Chinese) engineering, I'd like to know from someone with a good Aloris or Dorian toolpost, how much should it be, what's yours? I'd assume it should be a pretty close slip fit, rather than this sloppy 20 thou, but maybe that would bind up too easily, or there's some other reason it's undesirable?
I'm planning to turn and thread a shaft with a slightly bigger head (which will be the underside) and then press it into the reamed hole in the piece of bar that will become the T-nut. Since I'm doing it, it might as well be right.
