Parkerbender
Stainless
- Dec 19, 2009
- Kansas City Mo, USA
So, I have a bunch of bearing bores to cut in nylatron, and the first 30 came out big. 1.372 bore ended up 1.385 after the parts dry! In any case... so what does a person do with those?
Application is 8" diameter pulleys which run 5/16" nylon rope, 1.375" od, 17mm ID roller bearings, both sides. These pulleys will have the correct size (well, or way undersized depending on the temp and humidity) holes on the other side... does a guy dimple them with a spring punch, or wipe some mineral oil on them, or what is the right idea? They get out to 1.385 after a bit of baking, but stabilize around 1.381" in room conditions after dried out.
Now I am just cutting them .010" under where I was, being's you can press fit those bearings in that nylon if it was .015" small if you wanted to, and rather have the holes too small than to big... but I still have 30-some pieces of spendy nylatron gsm 8" round that have some slightly big holes in one side...
