Steelphil
- Feb 26, 2013
- Minneapolis MN
Long story short, I have about 60 threaded holes in some 17-4 PH Stainless. They are M10x1.0, What they need to be is M10X1.5...
Right now our engineers are looking at a few options to salvage these parts, I am going to be running some tests where I will be rerunning a tap down these threads to even see if this will work (It sounds like we will accept an ugly thread as long as it works..)
I have to admit, I have used a form tap once before, and I broke it.
I will be able to buy whatever tools I need to do this job, so I plan to have the best tap I can get my hands on.
My plan is to try roll forming a new M10X1.5 into the old thread and seeing how it looks. Can I get some help on lubrication, speeds and feeds, etc?
I have a New Haas vf3, that rigid taps like a pro, If it would be better I have a floating tap head, would that be better?
I am planning on using generous amounts of Castrol Molly Dee, is there a better suited lube for forms?
My workholding is solid, I am not concerned about that at all, however this is a thread into the end of a shaft with bearing diameters around the outside of the threaded section. I will be measuring the diameters, but with the bearind diameter measuing .750, I have .178 of meat beyond the major diameter. Am I at risk of deforming material that far out?
I have to drive this tap down .800 deep, will this be an excessive load on my spindle/break the tap? It will be only forming over the M10 x1.0 threads, so it probably has less to push through than a straight bore. If I can't run this all the way with the machine, is hand tapping okay with forming taps? I imagine keeping the tap straight is the most important, so I would do that with a tapping jig.
And I guess the last thing I could ask for advise on is speeds and feeds..
Thanks in advance for any insight you guys can provide.
