Foot switch on a drill press -- Anyone else using one??
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
    Jun 2003
    Thomasville, GA
    1,562
    6
    Post
    About six years ago, I installed a foot switch in parallel with the regular switch on my early-80s-vintage Craftsman drill press. I've found it very useful. I really like being able to turn it on/off without moving my hands.
    Has anyone else done this?
    Roger
    Apr 2002
    Syracuse, NY USA
    9,581
    16
    537
    Post
    yes. I also put a small air cylinder on them for self feeding, that is a very handy thing for production drilling. Two ways of doing it, mount it on the side attached to the ring on the quill or mount it on the top to push down on the center of the quill. a 3/4 inch bimba cylinder with a flow control is all you need, put a nylon end on the rod to act as a bearing and to prevent the rod from spinning, otherwise no solid connection. watch out for spiders!
  3. Likes oldbikerdude37 liked this post
    Feb 2004
    peekskill, NY
    23,681
    3878
    Post
    In my case, it was in series. So you needed
    the column toggle on, plus the pedal, to get
    it running. My old boss set his up that way,
    said the toggle switch was to prevent startup
    in "suprise mode."
    Once I put a VFD on the machine I had the
    toggle switch supplying ac to the VFD, and the
    foot switch becomes a low voltage logic line.
    Jim
    Feb 2006
    Indiana
    11,953
    441
    3139
    Post
    I use foot switches on my drill press, watch lathes, engraving machine and 1" belt sander. My flat belt drive Hardinge bench lathe has foot pedals to shift the countershaft belts and engage Hi, Lo or Rev. I have been switching on these machines with my foot for decades.
    Larry
  6. Likes Ron Hofer liked this post
  7. #5
    Sep 2005
    Northern California
    827
    98
    Post
    How you gonna tap in a drill press, without a foot switch?
  8. Likes John Welden, thomj liked this post
  9. #6
    Feb 2007
    aurora ohio
    1,097
    71
    176
    Post
    Used them all the time until the New and Improved OSHA model came along,like sticking your foot in a bear trap.The only thing worse than that ,was the OSHA plastic guard around the spindle & chuck.
  10. #7
    Feb 2004
    Chesapeake, VA, USA
    143
    Post
    About 50 years ago, my Dad had a well equipted wood shop in our two-car garage. There was no electricity installed, he had to run all the wiring himself. I came up with the idea to use a small box with a auto dimmer switch in it to act as a foot switch for the drill press, lathe, bench saw and others. He really liked it and it was still in use when he died, fifteen years ago.
    Steve
  11. Likes oldbikerdude37 liked this post
  12. #8
    Feb 2004
    peekskill, NY
    23,681
    3878
    Post
    "How to tap without a foot switch?"
    Procunier tapping head. Works great.
    Jim
  13. Likes beech, Greg White, Metalcutter liked this post
  14. #9
    Sep 2005
    West Virginia
    3,900
    362
    Post
    I was in an Amish woodworking shop a while ago. They were running mostly new Grizzly equipment with hydraulic motors retrofitted, and had footswitches on everything, including the drill press.
    Andy
  15. #10
    Jun 2006
    Kansas
    1,114
    192
    266
    Post
    I orderd a realy nice foot switch from Mc master Carr, I wired an extension cord cut in half. Now I have a foot switch that I can move around. The things I use it on so far is; weld positioner, scroll saw, pipe threader, and drill press. I love it.
  16. Likes oldbikerdude37 liked this post
  17. #11
    Apr 2007
    Port Orford Oregon
    111
    Post
    I have a reversing switch on my drill press. I have the switch on top of the electric box where I can run my power either straight from the reversing switch, or through the reversing switch, and then through the foot switch. That let's me tap while using one hand to hold the quill feed, and the other one to keep my vice from spinning.
    Tom
  18. Likes John Welden, thomj liked this post
  19. #12
    Nov 2003
    Beaumont, TX, USA
    4,112
    129
    1089
    Post
    I have a foot switch on my Unimat for 35+ years now. I use it in lathe, drill press, and all other modes. A great aid when you need both hands 100% of the time when starting an operation.
  20. #13
    Dec 2000
    Bremerton WA USA
    10,633
    40
    4048
    Post
    Back in the day I modified a bunch of Walker Turner and Delta three phase drill presses in a tool shop for tapping. It took a reversing controller and a couple of NEMA 13 control penel units but I got them all surplus.
    In tapping you run the machine continuously in reverse and the foot switch clicks in forward. That way the machine is fail safe, if you have reason to panic the machine reverses out more or less safely. These days you have to have an E stop that chops power when actuated and has to be reset for the machine to be re-started. Reversing a three phase motor with a light inertia load poses no electrical problem and it's well within the capabilities of a standard NEMA rated reversing starter with overload relay.
    This reversing arrangement will not work with a single phase motor. If the motor is above centrifugal swith speed reversing it will not change its direction. Only real two phase three phase and DC motors can be reliably reversed but the DC motor needs to have a current limiting feature on an electronic drive or a plugging resistor to do so safely.
  21. #14
    Sep 2007
    London, ON
    219
    13
    Just reviving this old thread ... since I'm (finally) getting around to adding foot switches to my 2 drill presses. And in doing a quick bit of research into the topic, here's why you definately DON'T want to wire your foot switch in such a way that it's live all the time ... Toolmaker76 learned this the hard way by accidentally stepping on his (live) switch while chucking a bit. Hopefully his accident will prevent many! Bill
  22. #15
    Mar 2009
    Eureka, CA
    3,293
    567
    997
    Son of a birch....that makes my cods quiver. Hope all turned out well!
    Stuart
  23. #16
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1002
    I have Forrests setup on my Clausing DP with a VFD also in control of the spindle motor.
    You must first "start" the VFD by powering it up. The fan runs. Then you use a green button-red button as a RUN-STOP controller. Varispeed via pot on the front of the VFD for spindle speed. There's also a selector switch under the RUN/STOP. Its DRILL/TAP. DRILL the spindle runs forward. TAP the spindle runs reverse.
    The footpedal is enabled only in TAP and it causes spindle to run forward. So you step on the pedal, use hands to align the work if needed and feed the tap. You decide enough thread is there, you let off the gas and the spindle stops for an instant then works its way back out in reverse.
  24. #17
    Sep 2007
    London, ON
    219
    13
    Quote Originally Posted by matt_isserstedt View Post
    Matt, I like that setup. Very slick ... and safe! Now I just have to find "Forrests setup" and hopefully see his pictures. Cheers, Bill
  25. #18
    Jul 2001
    North Carolina
    1,839
    125
    323
    I have a footswitch on a beltsander in my shop and it is very handy
    and seems pretty safe on the beltsander.
    Maybe try one on the drillpress if you are running a keyless chuck.
    That sounds pretty safe.
    --Doozer
  26. #19
    Sep 2007
    London, ON
    219
    13
    Quote Originally Posted by Doozer View Post
    --Doozer
    Well Doozer, "pretty safe" means different things to everyone. Try to imagine this ... you are in the middle of changing your belt on the sander and in the process of slipping it on the wheels, you didn't realize you had a finger under the belt on the in-running side of a roller as you were sliding the belt completely onto the rollers ... oh, and at that moment your foot just happened to step on the foot switch ... if your finger doesn't actually come off ... it's gonna be badly broken for sure.
    I'm just saying ... there is safe, and then there is safe. Bill
  27. #20
    Jul 2001
    North Carolina
    1,839
    125
    323
    Hey Bill.
    Don't get your finger stuck in the wheel spokes of your motorcycle.
    If you be too safe, you can stay in bed all day and not face the world.
    -Doozer
