Tumbling Advice?
Chuck Pool
Dec 20, 2006
Cedar Michigan
Hi to all:
I have a 3/8 inch o.d. copper tube wound into a slinky (coil) form. Its diameter is about one foot and its lenght is just under 2 feet with 3/8 inch spacing between the turns.
This coil needs to be polished shinny clean. Is there a way to tumble something this large? If so, would it be vibration type or actual tubling? I was think maybe a homemade 55 galon drum made into a vibration type tumbler. I don't know.
I need help with this one. Any one have any ideas?
Thank you.
Chuck
it may stress the material a bit.....if you do not have rediculious tolerances should not be a problem to vibe this part... if you can fit it
