Seekins
Stainless
- Jan 10, 2005
- Lewiston ID
I have a fairly new Atlas Copco GX5FF compressor (9 months old) and today it decided to start flipping the breaker. this is a single phase unit with a 40 amp breaker. Nothing has changed load wise in the shop and the temperature is always 65-72 degrees inside. The compressor has continually kicked on ever 3-5 min, runs for 30 seconds, then kicks off. Works great up until now. it has a total of 390 hours on it
the oil cooler/motor and everything else doesnt seem hotter than normal and you can put your hand on everything. but if we let it sit for 20min and try again it starts up and will be fine for aprox 3 hours.
Any ideas where i should start? could it be as simple as a bad breaker?
