GD&T - True Position
Results 1 to 9 of 9
    Apr 2005
    Brandon, MS
    769
    106
    139
    Default GD&T - True Position
    Let's say you're trying to hit dimension 0,0. But you really hit dimension 3,4. Through the Pythagorean theroem and such you do the formula SQRT(x squared + y squared) to find the hypotenuse and you end up off 5 from your intended 0,0 target.
    However, the way true position callout works, the formula is 2*SQRT(x squared + y squared), thus putting you off 10 (even though we just established that you were really only off 5).
    Anyone know why they double the number to get true position?
    Nov 2004
    Webster Groves, MO
    6,208
    1483
    2493
    If you bored a hole .005" off center, then indicated it from the correct position, you would read .010" TIR. Somehow, though, that doesn't sound like what you are describing.
    Bill
    Feb 2005
    8,382
    11548
    9393
    Simple, the true position is within a diameter, and you're calculating the radius.
  4. Likes Philabuster, nsaqam liked this post
    Jan 2007
    Newark, DE
    722
    8
    Quote Originally Posted by CatMan View Post
    Look on the true position callout - see if the true position tolerance number is a diameter or a radius. If it's a diameter, there you go - a .010 diameter true position is only .005 in radius. So you can either A) half the tolerance when you do the math, or B) just double your number.
    So, if the magnetude/hypotenuse of the errors comes out to be 5, and the tolerance is a .010 diameter, you've just taken up all the allowable error.
    Edit: Ooops, didn't see bobw's answer.
    Apr 2005
    Brandon, MS
    769
    106
    139
    OK. The diameter reference makes sense. Thanks guys.
    Jan 2009
    "Stuck in Lodi", Ca
    3,114
    1842
    1617
    Don't forget that the hole tol. can add to or tighten your true postion needed also. i.e. on a hole sized .5" +/- .010" making the hole .510 adds adds that .010" as a bonus to your true postion number.
    Steve
    Oct 2013
    CINNAMINSON, USA
    14
    Quote Originally Posted by scadvice View Post
    Steve
    A Hole size tolerance can only give you bonus tolerance If and ONLY IF you're given MMC. Boring a hole .5" +/- .010" to .510 with MMC adds .020 to your TP (not .010).
    In other words, for a hole .500 +/- .010 has TP of Dia. .010 at MMC (.490) If you bore the hole to LMC (.510) you get .020 bonus giving you a grand total of TP Dia. .030
    Side note: +/- .010 on a hole of .500 in my shop is like throwing a hot dog down a hallway. Bonus tolerance is more important with closer size tolerances. (+/- .002 or less)
    -CEM
  9. #8
    Mar 2005
    Kansas
    6,689
    355
    2877
    Quote Originally Posted by [email protected] View Post
    -CEM
    No.
    Whatever bonus you get from MMC diameter is added to the diameter positional tolerance, not the radial tolerance. So if the hole is .010 above low limit, there is another .010 on the diametral positional tolerance.
    Beware of LMC, where the hole size above low limit subtracts from the hole positional tolerance.
  10. Likes nsaqam liked this post
  11. #9
    Sep 2013
    SE PA
    5
    Quote Originally Posted by CEM
    -CEM
    In the example above, at .510, wouldn't he be .020 above the lower limit of .490?
    Quote Originally Posted by gbent View Post
    No.
  12. Likes Bobw liked this post
