lovedeep singh
- Sep 23, 2017
Hello
I want to manufacture shaft and small pinion as the single part.
I did separate calculations for shaft and gear but going to manufacture as single part. suggest me material and heat treatment process.
This single part is used in single stage gearbox 70N-m torque and 17Kw power. pinion has 20 teeth,2 module 20 Pressure angle and 22 Helix angle. facewith 30 mm
