Gluing copper to mild steel ?
Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Sep 2004
    RSA
    1,107
    394
    278
    Default Gluing copper to mild steel ?
    Could anybody recommend a good adhesive for gluing copper to steel ? I need to glue 1mm thick 6" dia copper disks on mild steel.
    Jul 2006
    Hillsboro, New Hampshire
    4,527
    996
    3096
    Almost any quality epoxy should work. More important is the temperature and environment (wet? oily?) the parts must live in. And surface preparation and cleaning prior to assembly is more critical than getting the exact right adhesive.
    Sep 2004
    RSA
    1,107
    394
    278
    I can clean everything very well. Must I etch the copper ?
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4053
    Soft solder. You can do it in a frying pan.
  5. Likes michiganbuck, randyc, eKretz, cranium liked this post
    Sep 2010
    Vancouver Canada
    656
    428
    206
    You get much better performance if you are able to sand blast both surfaces. Literally 10X the holding power compared to just cleaned smooth surfaces. I've seen Dan Gelbart perform this exact experiment in his 100 ton press with aluminum cylinders glued into holes. The difference is amazing. Maybe you can't mask or blast the surfaces completely but do the best you can.
    Oct 2009
    near Seattle, Washington, USA
    1,391
    304
    748
    What kind of environment does the finished product have to survive?
    Sep 2004
    RSA
    1,107
    394
    278
    Quote Originally Posted by charlie gary View Post
    Lapping machine...
  9. #8
    Sep 2004
    RSA
    1,107
    394
    278
    Quote Originally Posted by Forrest Addy View Post
    Now, that sounds interesting. How do I make sure the two surfaces touch one each other, stay flat ?
  10. #9
    Sep 2004
    RSA
    1,107
    394
    278
    Quote Originally Posted by rcoope View Post
    Good idea. I can't have any contamination of the copper surf but I'll see if salt for example, won't work.
  11. #10
    May 2004
    Vista, CA
    950
    228
    259
    Call Loctite and ask them (800) 562-8483 U.S.
  12. #11
    May 2017
    FINLAND
    1,128
    298
    532
    structural 2K acrylic adhesive would be my choice. Not so fussy about cleaniness as epoxy.
  13. Likes boslab liked this post
  14. #12
    Jan 2007
    Ontario, Canada
    492
    198
    448
    I never would have thought of that in a million years.....Thanks Forest.
  15. #13
    May 2006
    Seattle
    1,551
    26
    270
    Hopefully the application will keep the part at a narrow range of temperatures. There is quite a difference in thermal expansion between copper and steel. Copper coefficient is 16-16.7 and steel's is 11-12.5 so bad things can happen if the part heats up or cools down a lot.
    metalmagpie
  16. Likes digger doug liked this post
  17. #14
    Jun 2012
    Michigan
    8,564
    2551
    2912
    What ever you use a light sanding would be a asset to gluing and then no touching the glue area with fingers...
    Needing electrical passage solder or brazing needed.. light sanding needed for solder or braze.
    A small sliver of silver makes braze flow better..Think braze make +.005 in height..If I remember right
    Qt wild bill [Call Loctite and ask them (800) 562-8483 U.S.] good advice...
  18. #15
    Jul 2006
    4,527
    996
    3096
    Quote Originally Posted by metalmagpie View Post
    metalmagpie
    Yes, CTE is a good reason to stay with adhesive. I think I would stay with epoxy over acrylic adhesives due to better water resistance, which could be an issue in a lapping machine.
  19. #16
    Jan 2009
    "Stuck in Lodi", Ca
    3,114
    1842
    1618
    Yes, I agree sand blasting will improve adhesion. HOWEVER, sand blasting will warp that copper like a potato chip.
  20. Likes i_r_machinist liked this post
  21. #17
    Nov 2003
    Beaumont, TX, USA
    4,152
    131
    1100
    Or a toaster oven. I have an old one in my shop with one coil broken. It still heats up enough for soldering. I have done PCBs and some small mechanical parts with it. For one project I combined some large fender washers with some tubular spacers into some steel wire spools.
  22. #18
    Mar 2017
    CHINA
    1,813
    1127
    Explosion welding !!!
  23. Likes Bobw liked this post
  24. #19
    Sep 2015
    223
    13
    97
    I'm assuming you are trying to lap the copper disks and want to use a steel plate to back them. In that case, you could also use a spray adhesive. 3M has an extensive line of adhesives that may work. Epoxies will hold the parts together, however if you plan on removing the copper from the steel backing it will probably not survive. Solder will allow the copper to be removed, but the solder itself may prove difficult to get off the copper.
  25. #20
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4053
    Quote Originally Posted by AlexO View Post
    Clean and tin both surfaces. Clamp them gently, heat til the excess solder squishes out.
    Stay flat? That wasn't part of the original problem. If both steel and copper are thin, there will be some dishing because of different thermal expansion rates. But if the steel is thick and the copper thin there will be little distortion. If flat is important I suggest you provide stock allowance for post-solder machining.
    Soft solder takes place at 400 to 550 F depending on solder alloy. 2500 to 4000 PSI bond strength, again depending on solder alloy. I suggest a 95+% tin, 3% silver 0.8% copper alloy as being stronger, having better wetting, and lowest melting temperature of all but 37% tin 63%lead solder. Use the right flux.
  26. Likes AlexO liked this post
