gm & ford bellhousing bolt pattern needed
Results 1 to 16 of 16
    Sep 2006
    Buffalo NY
    132
    Post
    Hello everyone,
    Does anyone know where I can find bellhousing pattern dimensions for gm & ford? I am making a universal mounting plate for my friends dyno & have had no luck on the net. Any help would be great, Tom
    Dec 2005
    Kalispell, Montana
    1,257
    10
    Post
    Well the Ford will be easy, Just hit the wrecking yard and liberate a seperater plate that goes between the block and bellhousing, Instant pattern, Chevy bell housings should be everywhere,
    Jim
    May 2002
    South Central PA
    12,620
    1634
    2779
    Post
    The chevy pattern is published in the GM Performance parts 'Chevrolet Power' books, my 1994 edition has block prints for both BB and SB. I know I've seen the Ford patterns, I think in the old SVO catalogs but I'm not sure.
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1002
    Post
    I think SB and BB GM have the same? Seems like 4.3L, 5.7L and 7.4L could all be hooked up to a Turbo 400 transmission?
    Sep 2006
    Buffalo NY
    132
    Post
    Thanks everyone,
    I found what I needed @ chassis engineering. I searched for motor plates & found a ton of patterns. I need to get this plate drawn in auto cad, get back to work & cut it on the laser tonight. We are going to run two 360 sprint car motors in the morning. One Chevy & one Ford. Both have Engler injection, 13:5 comp. & run on methanol. Any guesses on wich will win lol. We are figuring both should be around 700 hp. Tom
    Jan 2003
    Central Kali.
    1,981
    12
    Post
    Take some pictures if you can.
    Feb 2006
    New Jersey
    1,421
    7
    44
    Post
    The one that will win is the one that will finish the race.
    Having said that, my money is on the bowtie
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,744
    1328
    2192
    Post
    Run them??
    On a dyno I assume.....
    Kinda wintry and cold outside.....plus the windchill
    at 100+MPH...
    Jan 2006
    scotland ontario
    114
    292
    29
    Post
    acutron would you keep us updated on what you find on the dyno. 360 cast block alum heads? ESS sprint? I think 410 were about 700hp not too long ago.I did not realize the 360 had progressed that fast. Just curious. Depending who built them but my money is on the Ford.
    Dave
    Sep 2006
    Buffalo NY
    132
    Post
    For the moment, the crazy wheather pattern here is keeping us fron doing any serious pulls. The humidity in the air is too high too risk anyones motor on the dyno & it is not that critical to run these motors right now anyway. D KIRBY, in the last few years the woo motors have reached the 800+ hp range due to the super light weight rotating components along with the metanol down nozzles. The 360's are benefiting as well from theses super light cranks & rods that are on the market today. With the right components & dollars to do it, a 360 can easily get to 700+.
  11. #11
    May 2008
    joliet IL
    34
    13
    Default Old thread reactivation powers activated!!
    Quote Originally Posted by acutron View Post
    Thanks everyone,
    I looked them up and only found one (chassisengineering.com) that listed motor plates, but there were no dimensions or measurements listed on any of them.
    There was also (chassisengineeringinc.com) but their web page is only page 1 of their catalog with no way to enter the site!
    I am in need of engine to bellhousing bolt and alignment pin measurements for the small block ford and the Buick 215 V8 so I can fab up a bell housing to get a C4 to fit my 215 Aluminum Buick V8 like it was made for it.
    Yeah, I know!
    I have the Buick engine and a C4 bell housing, so making a plate from or for either is no the problem.
    The issue is that the the crank shaft center line is unknown for either pattern, and without that, the alignment is a wild guess.
    I already have the blueprints for the Chevy 90 degree V6 small and big block V8's.
    They were the only ones I could find on line so I saved them even though I don't need them right now unless I decide to use a Powerglide in the near future.
  12. #12
    May 2006
    northwest ARK
    2,934
    4172
    395
    Advanced Adapters used to have a lot of dimensions. It was for identifying and deciding which adapter for mixing and matching jeep parts with others.
    They gave enough info that I built an adapter plate from their catalog.
    JAckal
  13. #13
    Jan 2007
    Norfolk, UK
    16,913
    12553
    12045
    Try a serch under V8 Rover,.... very popular engine over here, lotsa tuning houses etc.
  14. #14
    May 2008
    joliet IL
    34
    13
    Quote Originally Posted by Limy Sami View Post
    Been there and even to Australia harassing the Leyland owners for anything on the P76 (The name for their 4.4 liter version of the 215 V8).
    Quote Originally Posted by jackal View Post
    JAckal
    Been there as well, but I need the engine bell housing pattern with the crank shaft center line.
    I already have the Ford and Chevy patterns for the Powerglide and C4 transmissions.
  15. #15
    May 2002
    South Central PA
    12,620
    1634
    2779
    Is Buick V6 the same pattern? That might be an avenue to pursue - Jeep, etc..
    Another thought, Is measuring the block you have out of the question?
  16. #16
    May 2008
    joliet IL
    34
    13
    Quote Originally Posted by Mud View Post
    Measuring my block is my last resort as I am unemployed and going to school right now for career change towards AutoCad, but it's just more $$$ than I have right now to get a shop to do it.
    I might get lucky and the local college just might have a milling machine tall, and wide enough to do it.
    A photo or copy of factory blueprints are often most accurate.
    I saved all the $$$ and work by looking on line for the other Ford and Chevy small block patterns that I found.
