red5Apps
- Apr 15, 2013
- Gastonia, NC
This is a calculator for machinist and industrial engineers alike. New from Red 5 Apps.The functions included in this calculator are:
Price: Free Lite Version
Download Here:
https://play.google.com/store/apps/details?id=com.busX.machinistcalclite
Speeds and Feeds*
Revolutions Per Minute(General)
Surface Feet Per Minute
Surface Meters Per Minute
Inches Per Minute Milling Feed rate
Feed Per Tooth Mill
Feed Per Revolution
Inches Per Minute Lathe
Metal Removal Rate
Advance Per Revolution(Inches)
RPM with Carbide Tool(Milling)
RPM with HSS Tool(Milling)
RPM with Carbide Tool(Turning)
RPM with HSS Tool(Turning)
Horse Power
Thread Calculations*
Mill Tapping Feed rate
Lathe Threading Feed rate(Thread Lead)
Tap Drill Size
Percent of Full Thread
Mill Tapping Feed rate(Metric)
Tap Drill Size(Metric)
Percent of Full Thread (Metric)
Circle Calculations*
Radius of Circle
Diameter of Circle
Circumference of Circle
Area of Circle
Conversions*
Inches to Millimeters
Feet to Millimeters
Mile to Kilometer
Millimeters to Inches
Meters to Inches
Kilometers to Miles
Cutting Time in Minutes(Mill)
Cutting Time in Seconds(Lathe)
G and M codes*
List of Standard G and M Codes
Oblique Triangle Calculations*
Side, Angle, Side
Angle, Angle, Side
Side, Side, Side
Sine Bar Stack Height*
Download Here:
Speeds and Feeds*
Feed Per Tooth Mill
Feed Per Revolution
Metal Removal Rate
Horse Power
Tap Drill Size
Radius of Circle
Diameter of Circle
Area of Circle
Conversions*
Feet to Millimeters
Mile to Kilometer
Meters to Inches
Kilometers to Miles
G and M codes*
Side, Angle, Side
Angle, Angle, Side
Side, Side, Side
