I am trying to figure out how I can replicate how this guy is making the tapers within the bore of these wood flutes. http://www.mcgee-flutes.com/making.html
I believe that the whole process can be done on a metal lathe much more accurate than a wood lathe. I am literally stumped on how to machine the internal bores on these things if I have to use a gun drill to take it to the smallest diameter and then somehow get the finished taper bored out. It appears he's got some tapered reamers (possibly custom made). Should I be considering using a long boring bar to establish the rough taper and then having a custom tapered reamer made for the finished bore? Anybody that thinks these instruments are an easy thing to make, need to reconsider the idea!
Thanks for your ideas and wisdom!
Dave
Dave
