gun drilling on lathe
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
    Mar 2009
    Brunswick Oh USA
    4,244
    4252
    2492
    Default gun drilling on lathe
    If there's enough interest in doing this on a conventional lathe, I'll go through all the steps. If not I'd rather not go through all the typing and picture taking. First off, what you need is about $1100.00 in an air over coolant pump and a gun drill. This is NOT like an Eldorado or other, but will result in very accurate drilling. Also what you need is a good lathe with approx. 2 - 3000 rpm with a feed rate of
    .0005'' or less. The tougher and or harder the material the lower the feed rate should be. Response?
    Ray
    on edit: Go down a ways and I'll show you how I made this thing.
    Sep 2008
    Anytown, USA
    334
    47
    38
    Sounds like an interesting read and could prove very helpful to many who don't have the facilities to gun-drill conventionally.
    Sep 2008
    Leics UK
    42
    Always interested in learning more 'esoteric' techniques, they come in handy when others will not do.
    Dave
    Jul 2009
    Cobblers Knob, IN USA
    1,106
    6
    I would read it with interest, but not be able to apply it. At least not directly; never know what I would pick up and use elsewhere.
    Feb 2002
    Albany, OR 97321
    485
    20
    I would very much like to see this.
    GsT
    Dec 2008
    Charlotte, NC
    629
    164
    138
    If you write it I will copy it and archive it on my hard drive. I don't know when, if ever, I will piut it into application though.
    Vlad
    Feb 2006
    South Carolina
    345
    39
    Love to see it.
    Aug 2002
    Sinton, TX.
    253
    14
    Please do.
    jim
    Nov 2004
    Webster Groves, MO
    6,208
    1483
    2493
    I gun drilled a bunch of transformer cores on my 15" Sheldon lathe, having to work it all out myself. I will be interested in your solutions.
    Bill
    Nov 2005
    Maryland
    8,508
    741
    1059
    Thumbs up One more yes
    Hi Ray,
    I would certainly be interested.
    I don't do any gunsmithing since I let my FFL expire, but I expect the techniques would be applicable to other deep-hole work.
    Thanks.
    - Leigh
  11. #11
    Mar 2009
    Brunswick Oh USA
    4,244
    4252
    2492
    Well good, there's interest! I have a recurring job that requires a 21'' deep hole in 1 3/4'' piston rods for a sensor in some sort of hydraulic cylinder. Getting sick and tired of peck twist drilling that deep with 4 different length drills I bought a Sterling Gun Drill for the lathe. The first pic is the coolant unit. It operates on 100 psi which blows the air through the hollow drill, plus operates an air powered piston booster pump to inject coolant into the mix. The next pic is a 1/2'' x 22'' gun drill.
    Now comes the way I made a drill mount to fit my lathes. It has a 1/2'' base with a 3'' piece of bar stock welded to upright supports. I rough drilled the bar stock to 1 5/16''. Stuck the drill bit in the lathe chuck and slid the bar on it. Now I can measure the height between the bar and base plate for support ribs. The pieces are cut and holes drilled to fit the T slots of the cross slide. After I welded the assembly together I flycut the base bottom because of warpage
    OK, now that it's roughed in it's mounted to the cross slide. I used dowels to align it to the T slots, but don't think it's necessary. I also made one for my 13'' Sheldon which you can see mounted where the compound was. Next to that one is the drill bushing I made to hold the drill to the support.
    Tomorrow I'll show how to make things true to everything.
  12. Likes Jashley73, greenbuggy liked this post
  13. #12
    Aug 2006
    Hesperia, SoCal
    4,369
    987
    629
    We'll be here, thank you. I'm most curious how you adapted your drill holder to the air and coolant, lessee, O-rings.......
    Bob
  14. #13
    Mar 2009
    Brunswick Oh USA
    4,244
    4252
    2492
    Quote Originally Posted by Robert Campbell Jr. View Post
    Bob
    Bob,
    Nope, it's even more niftier than that! Gotta go take more pics of this mess.
    Ray
  15. #14
    Aug 2002
    Sinton, TX.
    253
    14
    Do take some pics of your stock holding/centering setup on the
    back end of your head stock. Thanks for the good photos.
    jim
  16. #15
    Nov 2007
    marysville ohio
    8,626
    2444
    5468
    Why is everything so big that I have to scroll back and forth to see and read everything? Can I make it smaller on my computer?
  17. #16
    Nov 2008
    Perth, Western Australia
    41
    7
    G'Day Ray,
    I think this is a great thread!!!!
    I personally would like to see a few more details about the gun drill itself. Having never seen one, I am very interested in it's sectional profile and it's cutting edges/point angles etc. What material is it made from? Is it ground true?
    I am looking forward to the next installment.
    Cheers,
    Phill.
  18. #17
    Aug 2009
    Royersford PA USA
    276
    Quote Originally Posted by moonlight machine View Post
    It's because the pics are so big, there's nothing you can do about it. Ray could make the pics smaller though.
  19. #18
    Oct 2009
    Portland, Oregon
    3,541
    3768
    1739
    I'm very interested to hear how this works! Please give details on the process and the drill!
  20. #19
    Jun 2005
    Edmonton,Alberta,
    1,180
    140
    90
    Great projects; both doing it and documenting it for us. Pictures are clear and well done. I prefer to scroll a clear picture than look at a small poorly defined photo.
    Raymond
  21. #20
    Jan 2005
    CANADA
    Saskatchewan
    9,435
    1138
    3175
    I'm using IE and I found out the other day while fat-fingering my mouse and keyboard, that if one holds down CTRL and zooms with the scroll wheel of the mouse, that everything shrinks real small, real fast But it will resize stuff for a quick view
