H13 Slot Tolerance Question
Results 1 to 7 of 7
    Oct 2003
    Delta, OH USA
    Post
    I have a print for a pin approx 4.00 Diameter with a slot across one end. The width of the slot is 10.5mm with an H13 tolerance called out. What I am trying to figure out is what is the H13 tolerance and how to apply it to the slot width. I did find one chart on the internet that seemed to say that the tolerance was +.27 / -0 . If that is true, the slot width would then be 10.5 / 10.77. Just hoping that someone can provide some insight to how this shoud be interpeted.
    Woody
    Aug 2004
    Centerville,OH
    2,110
    60
    Post
    I have looked at my charts, both German and Japanese, and i cant find any callouts over H10. However, if you found one that says +.27/-0, then you are correct in your interpretation.
    I usually go to the Misumi site technical data when I need info fast. Here's a link to the chart I refer to: JIS B0401 Good Luck! -Mike
    Jul 2004
    Asheville NC USA
    8,948
    3392
    2978
    Post
    Same here. Found one that goes to H11, which is -0/+.11 for a 10.5mm hole (or slot). H will always be -0/+something. Increasing numbers mean greater limits, so your +.27 sounds reasonable. Translated to 'merican, minus nuthin, plus about 10 thou, which makes it sound quite a bit tighter than +.27
    May 2003
    Iowa
    10,065
    3191
    3866
    Post
    Woody,
    H13 is a pretty sloppy fit. You're right, the tolerance goes to the big side for holes. My charts only go up to H9 and for that size hole the tolerance is +0.09mm (0.0035"). If you found one that says 0.27 that's about +0.010".
    JR
    Oct 2003
    Delta, OH USA
    Post
    The Chart that I found the info in is located at:http://www.engineersedge.com/iso_tolerance.htm
    The last chart on the page is Tolerance Zone in MM (Internal Features)
    Mar 2005
    Northwest Indiana
    3,353
    335
    431
    Post
    Woody, I see similar stuff on some parts we do...the slot is likely for a retaining plate, which is probably 10mm thick. These do not need to be precision fit, as there is usually .5mm or 1mm clearance between the retaining plate and the slot to begin with, so your +.27mm or +.010" is very likely correct.
    Mar 2005
    Germany
    472
    41
    Post
    You'll find the tolerances here:
    http://www.tiefbohren.info/Buchstabe...oleranzen.html
    Your range is >10-18 mm, so for a tolerance of x13 the span is .27 mm.
    For H fits (H13), lower limit is always 0, so your calcuation of 10.50...10.77 is correct.
    Benta.
