Considering a Haas VF-3. also in the running is a Mazak VCU 500 or NEXUS 530
I tend to steer away from the Mazak VCU because of the stationary table and reduced rigidity in regards to the nexus or vf3 which can run a 50 taper.
We will be running large drills and doing moderate/heavy milling
Fairly general machining, mostly mild steel.
It's to replace a 4020 fadal.
Thoughts?
Thoughts?
