Pete F
Titanium
- Jul 30, 2008
- Sydney, Australia
I wonder if those who use a Haimer 3D Taster could let me know what repeatability they're getting when touching off a zero and then rotating the spindle so the Taster is indicating the same surface but from different directions in respect the instrument (I hope that makes sense). So with the instrument facing you zero to a vertical surface to the right, zero the DRO, rotate the spindle 90 degrees (the Taster face will obviously now be to one side), touch off there and compare DRO readings, and so on to the back and then to the other side. I'm a little disappointed in mine lately and I don't recall ever being concerned about it before.
I broke a probe and replaced it, then adjusted it for concentricity. Then did the same for a second probe. I finished up making up a 23 mm pin spanner and pulling the whole Taster apart today and couldn't see anything at all that might lead to this sort of unreliability. Using a standard edge finder I can repeat to 0.01 mm no problem, but the Taster is at best only repeating to about 0.05 mm and just isn't giving me confidence in the readings. I've dicked around forever on the concentricity and feel it's about as good as I can get it.
Another method I used to indicate off the same surface was to touch off one, the butt a gauge block up against the surface and touch off the gauge block so it was on the opposite side of the probe. I haven't however tried that method since pulling the thing apart, so will try that tomorrow. The advantage with this method is nothing moves, and the probe simply goes from one side to the other so it pretty much isolates any chance it's sitting in the machine incorrectly etc.
