Don2222222
- Dec 7, 2013
- Wheatland, WY
Trying to repair a window regulator gear from an old Dodge truck for my boss. What is the best method for ensuring proper gear mesh, tooth height and radius match... I will begin my second try on Monday, any suggestions for toolup would be appreciated.
The gear is a simple stamped steel regulator gear that has worn out at the top few teeth. I welded some blobs onto them and did some basic measurements with calipers and a mic, but when I finished it, it wasn't right, i think that the tooth height is wrong causing slippage from the repair point.
Thanks in advance for any constructive input.
