oregonclockmaker
- Aug 9, 2004
- Willamette Valley, Oregon
So I've got a part that needs a finished hole of .125" to fit over a stud that is slightly (.1245) smaller, and still rotate freely. Having never power reamed anything that small, I decided to order a spiral flute hand reamer.
Since I only need to do one of these, I opted for the "import" reamer from MSC. I got it, reamed the hole, and....it doesn't fit.
Checking with the gage pins, a .124 just barely slides into the hole; the .125 doesn't. It would appear that the reamer is slightly undersized.
So, is the problem a) I'm expecting too much accuracy from a hand reamer, and +/- .001 is within their normal limits; b) I should have gotten a straight flute reamer, or c) I shouldn't have been a cheap so-and-so by choosing the "Made in Bosnia" import over the undoubtedly better USA brand?
The answer will determine whether I send the reamer back for credit.
-=[ Grant ]=-
-=[ Grant ]=-
